Voicemail prompt record
Discussion in '3CX Phone System - General' started by koshy_vimal, Mar 18, 2009.
  1. koshy_vimal
    Jan 13, 2009
    15
    Dear all,
    Can I record my own statement as a voice mail prompt? If yes, in what formats and how do I upload it?
    Thanx,
    Vimal
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You can record this via the voice mail options when dialing in your voice mail.
    When in your voice mail, You need to press option 9 to go to the Voice mail options menu ad then press 8 to change your voice mail greeting.
    Info also found on http://www.3cx.com/manual/3CXExtensionmanual7/extension7.html
    regards
  3. koshy_vimal
    Jan 13, 2009
    15
    Hi there,
    Thanks for the solution
    Regards
    Vimal
  4. verdun
    Oct 27, 2009
    Hab das bei Version 8 jetzt mal so gemacht. Geht auch an die Message. Am Ende kommt dann ein Piep und dann spielt es leise Musik im Hintergrund.
    Dann bekomme ich eine Datei, auf der nur ein Piep Piep in Abständen zu hören ist. Woran kann das wohl liegen?
  5. verdun
    Oct 27, 2009
    Sorry wrong language . I have done tzhe recording and the voice prompt works, but after the piep there is quiet music in the backround and the recording is only bring a piep piep in intervals instead of the actual message.
