- Joined
- Aug 28, 2015
- Messages
- 2
- Reaction score
- 0
I'm not sure if there's a solution to my problem but I hope there is.
Basically, we have multiple phone lines for different companies dialing to the same extensions. Now, for voicemail purposes, we want a voicemail that changes on depending which line the customer is calling in but it seems voicemails are based off extension. So the voicemail for one company won't work for the others.
From what I've looked at, I don't seem to see a solution but I could have overlooked some settings to get the desired outcome I am requesting.
Hope someone can help and hopefully the problem is clearly explained above.
Thanks in advance.
Thanks in advance.
