Voicemail - Server Failure
Discussion in '3CX Phone System - General' started by peterbunn, Jun 3, 2009.
  1. peterbunn
    Jun 3, 2009
    20
    Everytime I transfer a call to voicemail, it just says, server failure and ends the call.
    Anyhelp would be appreciated!
    -Pete
  2. theromans
    Dec 22, 2008
    15
    If you use IIS have a look into the web config.
    I have found that something in IVR wouldn't work if you speciy the IP address to serve.
    Leave IP undeined, i.e. it will serve all requests for localhost.
    That fixed my prob with IVR
