voicemail storage location
Discussion in '3CX Phone System - General' started by netswork, Mar 13, 2014.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I know you can change the location of recordings but is it possible to change the location of the where voicemails are stored?
  2. netswork
    Mar 11, 2011
    577
    also is there a setting to have the system delete voicemails after a certain time period?
  3. carolinainnovative
    May 4, 2009
    369
    6
    (sigh) unfortunately I have yet to find a way to do either of these...
    I would love to put the entire 3cx folder on, say, the D: drive - or hey, even just a few of the folders that have content that can grow - voicemails, provisioning files, firmware, etc - but alas, I haven't seen a way yet.
    I 'sppose you could mount a disk for those folders - Windows/NTFS does support that now - and that would allow you to put it on a SAN or something - or even just a different disk - but I haven't found any way to actually relocate them out of C:\ProgramData\3cx*.
