voicemail text with out recording message caller
Discussion in 'Ideas' started by gweijkamp, Sep 2, 2016.
voicemail text with out recording message caller 5 5 2votes
5/5, 2 votes
  1. gweijkamp
    Nov 25, 2008
    6
    we have been asked for a solution where on extension level the user can record its personal voicemail message, but to choose either for the caller to leave a message or disable the caller message recording. in that case the personal message is just a announcement/notification once played the systeem will end the call.
    the option should be selectable on extension level with either be able to record the callers message or to use the voicemail just as an announcement system.
    looking forward to your replies
    GCollis and Rinok like this.
  2. Rinok
    May 19, 2017
    we Need this Feature, too.
    Other products do Support it right now
  3. GCollis
    Dec 11, 2014
    39
    6
    Nice idea, on the voicemail tab it would be nice to have a checkbox or drop down which lets you choose.
