Voicemail - This call could not be completed
Discussion in '3CX Phone System - General' started by adammason, Feb 20, 2012.
  1. adammason
    Dec 21, 2011
    14
    Since moving server and backing up the database, restored fine and all is functional apart from when any phone calls the Voicemail. It says 'This call could not be completed' same with if a call to a devices rings off to voicemail produces same message.
    Any ideas?
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Have you changed the web server? What server are you using? Check logs for any errors and post them here.
  3. adammason
    Dec 21, 2011
    14
    17:18:23.480 [CM503008]: Call(17): Call is terminated
    17:18:19.487 [CM503007]: Call(17): Device joined: sip:900@127.0.0.1:40600;rinstance=6d5de58eb98145b0
    17:18:19.481 [CM503007]: Call(17): Device joined: sip:106@86.162.230.###:1024
    17:18:19.231 [CM503025]: Call(17): Calling Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=6d5de58eb98145b0]
    17:18:19.191 [CM503004]: Call(17): Route 1: Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=6d5de58eb98145b0]
    17:18:19.183 [CM503001]: Call(17): Incoming call from Ext.106 to <sip:900@81.136.160.###>
    Could it be to do with the 127.0.0.1 ?
    Also I have used IIS instead of the other webserver..
  4. danhriscanu
    Nov 29, 2011
    232
    This is ok. 999 its a system extension registered on localhost. Are you using public IP for your extensions like 86.162.230.###?
  5. adammason
    Dec 21, 2011
    14
    I changed it default voicemail to 900.. didnt want 999..
    Tried changing back made no difference
    Yes Public IP, as we are using extensions from a few locations, home and mobile..
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    try to find location of 3CXIvrServer.log/3CXIvrServer.trace.log and post it here.
    To make things simpler, restart Digital receptionist service. Replicate problematic call. "zip" those files and attach archive to you post.
  7. adammason
    Dec 21, 2011
    14
    Seems like this is the error
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Your webserver is not running or http://localhost:5000/ivr is not accessible.
  9. adammason
    Dec 21, 2011
    14
    Currently reinstalling IIS and 3cx.. will post update.. thanks for your help!
  10. adammason
    Dec 21, 2011
    14
    Fixed.. Thanks again
  11. SY
    3CX Support
    Jan 26, 2007
    1,825
    Re-installation was not required. Unfortunately, we have not investigated this precedent here :(
    Anyway, I'm glad to know that problem was solved.
    Regards
  12. nupton
    Oct 5, 2007
    26
    We're having the same issue and I really don't want to reinstall. Using abyss, What is the not reinstalling fix?
  13. SY
    3CX Support
    Jan 26, 2007
    1,825
    Open Service Control Manager and restart (or start if it is not running) Abyss Web server.
  14. hostone
    Dec 20, 2010
    Every time I have seen this issue it's been related to the web browser. Usually the cause is .NET (updated .NET patches, etc).
    2 choices: check .NET etc and then restart IIS. Usually fixes the issue.
    or
    Switch to the Abyss Web Server (3CX) instead of IIS if you don't need the other IIS features of the product (like MyPhone chat client etc).
    I also notice the IIS option never seems to work on a desktop version of Windows.
  15. MrKoen
    Jul 3, 2009
    61
    Genious! Encountered the same problem. This hinted for me that I just had changed the default port HTTP 5000 to port 80. Added HTTP 5000 back in IIS manager and it was up and running again. Thanks!
  16. bsloan9858
    Feb 1, 2012
    8
    3CX support, I'm having the same exact issues but with using the built in web server on v14SP3. I posted my issue in the forum but no one has yet replied. Can you please help!
