Voicemail Time Limit
Discussion in '3CX Phone System - General' started by adetterer, Mar 20, 2009.
  1. adetterer
    Aug 28, 2007
    22
    Is there a way to set a time limit on voicemail so that it completley disconnects the call after a set amount of time?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,580
    115
    There is a time limit it's around 1min 59 seconds if i remember correctly.
