Voicemail
Discussion in '3CX Phone System - General' started by hobbit666, May 13, 2011.
  1. hobbit666
    May 11, 2011
    Is there a way of changing the way people leave messages?
    I would prefer the person not available message to happen, then the peep. Then the customer just leaves the message and hangs up.
    I don't want the customer to have to press extra keys just to leave a message.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    the only options for voice mail are in the Extension details tab:
    Enable Voice Mail
    Play Caller ID
    PI Number
    Read out date/time format
    email options.
    this is already an option. You don't have to press any buttons to save the message.
  3. hobbit666
    May 11, 2011
    oh, ok.
    It's just when the recorded voice comes on it says press # after the message.
    Will have a play today and test, as need to get E-mail's working
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    yeah most VMail setups say that but it isn't necessary.
  5. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    you may wish to record your own voice mail greeting.
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    you could do that. record your own .wav and replace the prompt called: "record_your_message" and be sure name the new prompt the same as the original.
