VoiceMail
Discussion in '3CX Phone System - General' started by quayfour, Aug 30, 2011.
  1. quayfour
    Dec 1, 2009
    12
    I am trying to access voicemail remotely to pick up messages / change greetings - we do not use the digital receptionist.
    Is it possible to be transferred to an individual extension's voicemail box and then access it using the PIN ?
  2. willow
    willow Member
    Mar 1, 2011
    471
    when you try and access your messages with the 999 code just press # and then enter the extension number and pin to check the messages. I do not know of a way to be transferred to a mailbox and then enter the pin outside of someone transferring you to 999 (or the voicemail code) and then press #.
  3. leejor
    10,767
    286
    Have a look at these posts http://www.3cx.com/forums/cannot-retrieve-voicemail-from-outside-system-20508.html#p103286
    It involves setting up a DR, AND relies on the fact that you don't already use the operator extension (although, you can get creative in the DR to get around that).
