Voicemails don't save if caller hangs up
Discussion in '3CX Phone System - General' started by fpuser, Aug 1, 2007.
  1. fpuser
    Aug 1, 2007
    Usually when someone leaves a voicemail on another persons phone, they hang up their line when they've finished with what they have to say. However, when i get voicemails through my VoIP system, they will only save if the person leaving the voicemail presses 0 to end the call and # to save the message when they're done. Is this just a setting that i can change to make the message save when the line is cut off, or does 3CX not offer that?
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    No it should save without having to press anything. Just tried it and works fine. Message light went on 2 seconds after hanging up. Call Assistant did the same.
    Can you try it with another extension?
    Post your log files from the call.
    Here's what mine say:
    17:45:28.626 StratInOut::eek:nHangUp [CM104007] Call(82): Call from Ln:10001@nV to 999 has been terminated by Ln:10001@nV; cause: BYE; from IP:66.23.129.253
    17:44:55.985 CallConf::eek:nProvisional [CM103003] Call(82): Ext.100 is ringing
    17:44:51.017 MediaServerReporting::DTMFhandler [MS211000] Call(82) Ln:10001@nV: DTMF (RTP) from 69.30.45.229:40530 arrived. in-band DTMF tone detection is turned off.
    17:44:44.407 CallLegImpl::eek:nConnected [CM103001] Call(82): Created audio channel for Ln:10001@nV :)40530) with Media Server (70.88.47.78:9004)
    17:44:44.282 CallConf::eek:nIncoming [CM103002] Call(82): Incoming call from 8603450011 (Ln:10001@nV) to sip:18607406213@66.23.129.253
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi fpuser,
    Which version in use? The current 3CX Phone System v3.0.2328.0 works fine.
    Please found more information about VM as below:
    When you close the phone without press anything, it will save the message.
    When you press # then you press 0 , it will save.
    When/if for some reason the line stays open for 2 minutes, the voicemail will stop recording after 2 minutes and save.
    When you press # but you don't press 0 it will not save
  4. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    5qg4 is right. This was indeed the behavior on a previous version (3.0.1928)
    In the current version this was fixed.
    Regards
  5. fpuser
    Aug 1, 2007
    v3.0.1928.0 is what i'm running, so that must be the problem. I will update as soon as possible and hopefully that will fix the problem. Thank you.
  6. Costas3CX
    Jan 23, 2007
    217
    You are welcome... After all, we are all here to help and build a community of users that are happy using our phonesystem. Please feel free to ask any other questions you may have and we will try our best to help you....
