Voicemails not showing correctly
Discussion in '3CX Phone System - General' started by featherston, May 8, 2015.
  1. featherston
    Jul 2, 2014
    5
    We have a client on version 12 of 3cx, using all T41ps. They have some phones that are showing 20-100 voicemails and when they hit the voicemail button it shows 0. I have them all on the 3cx recommended firmware. They are also using the windows SBC to connect to their 3cx server in our datacenter. I also changed a few to STUN and it seems to still occur.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please check what's in the voicemail folders for the said extensions : C:\ProgramData\3CX\Data\Ivr\Voicemail\Extensions
