VoiceStick configuration
Discussion in '3CX Phone System - General' started by Roys, Sep 15, 2007.
  1. Roys
    Sep 15, 2007
    Can you help me with the configuration for VoiceStick Voip provider? Im able to connect using SJphone but cannot connect using 3cx.
    Any ideas or people using it?
    Roger
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  3. Roys
    Sep 15, 2007
    Config
    Thank you for your prompt reply.
    Im using this:
    Registrar/Proxy Hostname or IP: i2telecom.com
    Outbound Proxy Hostname or IP: 206.165.50.116
    both Ports: 5060
    Stun server: blank
    user: 1xxxxxxx (my number)
    and my password
    when i use this exact configuration on the sjphone, it works, and when conecting on the 3cx it states:
    ClientRegs::eek:nFailure [CM113006] Registration of sip:1xxxxxxxx@i2telecom.com has failed; reason=SERVICE UNAVAILABLE
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Have you checked the firewall on both the 3CX machine and at the router?
