Void option "Press Star" in Vmail
Discussion in '3CX Phone System - General' started by biker29r, Aug 28, 2011.
  1. biker29r
    Aug 23, 2011
    13
    How can i avoide this possibility? when some one reaches my Vmail, i want a message- nothing else offered ("star for receptionist" - i dont have one...). It can be done for the extension or the whole system- both are OK for me. Thanks!
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    you have to pick an operator extension no way around it. This is something you cannot avoid.
    Thanks,
    Nate
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    It would be nice to have a option for defining operator per extension group, this way you will achieve greater flexibility (and much of a tenant functionality). Also missing (not-defined) operator should disconnect the call.
    Regards
  4. biker29r
    Aug 23, 2011
    13
    OK, lets assume i have a "receptionist" which i do. On a certain inbound rule, i have the calls go to an extentions VMail (not receptioninst ext.). Now, all i want is for the caller to leave (or not) his message on this VM. I do not want him to have the option "press star" - better yet - i do not want the extensions VM to have the option "Press Star"!
    Now, is that doable...? Thanks!
  5. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Eagle2, you know the drill :) 3cx.ideascale.com I can see how useful that would be.
    biker29r, no that is not possible. Disabling functions in voicemail I mean.
    Thanks,
    Nate
