VoIP C# library for 3CX PBX
Discussion in '3CX Phone System - General' started by luke880, Feb 11, 2015.
  1. luke880
    Feb 11, 2015
    We use 3CX as a corporate PBX and I need to create a C# SIP telephone application with some extra company-specific features (some additional call center functionalities) that will be used to make huge amount of simultaneous calls through our PBX.
    I didn't find any proper C# API for 3CX, so I think I need to use a third-party C# library suited for this purpose to implement the VoIP backgroud of the application. I am newbie in this field and I need some suggestion on which library is the most suitable in my case.
    I found many related tutorials on the web that uses Ozeki VoIP SIP SDK. According to this page it's 3CX-compliant: http://voip-sip-sdk.com/p_124-3cx-pbx-setup-voip.html. It looks good, but this is a commercial product... and I'm afraid, its trial period is not enough. So, I'd rather use an open source one - if available at all.
    What do you think about this? Do you have any experiences with Ozeki VoIP SDK in long term in corporate use? Is it appropriate for 3CX? Or can you recommend me a good (and free) alternative to this library?
    Thanks,
    Luke
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    You can use the 3CX Call Control API for this purpose : http://www.3cx.com/blog/docs/call-control-api/
