VoIP call disconnection
Discussion in '3CX Phone System - General' started by tomlinm, Dec 23, 2008.
  1. tomlinm
    Oct 27, 2007
    20
    Hello all
    V6.1.0 (Windows 2003 Server)
    Call comes in via VoIPtalk line
    PSTN > VoIPtalk > DR > Ext > Voicemail
    If a call follows the above route, and a caller hangs up during voicemail without pressing #, the disconnection is not detected...if a call hangs up at any other point during the call, disconnection is detected without a problem
    I have tried this using the nat.voiptalk.org:5065 and also the natproxy.voiptalk.org
    any thoughts
    Mark
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    If you capture such a call with Wireshark do you see the DTMF # signal coming inbound from Voiptalk to 3CX?
    Also, when the caller ends the call, there should be a BYE coming from VOIPtalk to 3CX. Do you see this in the capture?
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    is wireshark must be installed on the 3cx server
    or can be on a pc in the same lan
    please explan how to capture a call using wireshark
  4. tomlinm
    Oct 27, 2007
    20
    Hello
    I do not see the BYE packet from VoIPtalk when in the voicemail section of the call, the 3cx box eventually sends a BYE to VoIPtalk ending the call.
    However, during any other section of the call, VoIPtalk does send a BYE to the pbx
    I have also raised this with VoIPtalk
    Mark
  5. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    Wireshark must be installed on the same machine as the 3CX PhoneSystem to ensure that all the relevant packets are captured.
    Regards
    Kevin
  6. Ads
    Ads
    Aug 15, 2007
    16
    Hi tomlinm (mark),
    I'm having a very similar issue to you see: http://www.3cx.com/forums/calls-routed-to-voicemail-remain-connected-9624.html
    I also use voiptalk as my SIP trunk provider and was wondering if you still have this problem or found a solution?
    Thanks,
    Ads.
  7. ciscotech2007
    Jan 27, 2009
    94
    Sounds like your VoIP trunk provider is not acknowledging the hangup and issuing a BYE SIP message to deconstruct the SIP sessions(your call).
    Speak with your VIP provider.
