Voip Call from Cellphone
Discussion in '3CX Phone System - General' started by vin944, Sep 15, 2008.
  1. vin944
    Aug 20, 2008
    7
    I have a 3cx PBX setup and I have one Voip line registered. Is there a way I can call in to my PBX and be able to make LD calls to China using my VOIP line? Thanks.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Do you have pstn gateway ?
    do you want to call your landline then 3cx dial from voip line ?
  3. vin944
    Aug 20, 2008
    7
    No I don't have a pstn gateway. For example I can set ext 200 to always forward to outside line. If I call from my cell to the main digital assistant (using IPKall) I can press 0 for ext 200 and that will forward to whatever number I have programmed. I am looking to do the same thing except without the programming part. Thanks.
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Sure you can do this as preprogrammed key or number
    And you can work around to dial any number
    But you dial ipkal number to dial with which line ?
  5. vin944
    Aug 20, 2008
    7
    The IPKall is just forwarding to 800@mydomain.com. I have a digital assistant set up there (800). I have 10 preprogrammed numbers which go thru my voip provider. But it seems like if the number is not preprogrammed then I can't use my cell to make an LD call. Is this correct? Thanks for your help.
