VOIP Cheap UK
Discussion in '3CX Phone System - General' started by tazz, Sep 13, 2007.
  1. tazz
    tazz New Member
    Sep 12, 2007
    124
    I'm having some Challenges with getting Voip Cheap UK to register. Does anyone have some screen shots to share with me?
    Thanx
  2. etm_ltd
    Nov 18, 2006
    69
    Hi tazz,
    First, you must have a VOIP-IN number: cost € 1.00 and it is easy:
    Here is VOIPCHEAP parameters:
    SIP port : 5060
    Registrar : sip.voipcheap.co.uk
    Proxy server : sip.voipcheap.co.uk
    Outbound proxy server : leave empty
    Account name : your VoipCheap username
    Password : your VoipCheap password
    Display name/number : your VoipCheap username or voipnumber
    Stunserver (option) : stun.voipcheap.co.uk
    From left panel: ADD VOIP
    Give a name: e.g VOIPCHEAPUK
    select Generic then NEXT
    complete page with
    Registrar/Proxy Hostname or IP => sip.voipcheap.co.uk
    Registrar/Proxy Port => 5060
    Outbound Proxy Hostname or IP => Empty
    Outbound Proxy Port (default is 5060)
    STUN server Hostname or IP => stun.voipcheap.co.uk But optional
    STUN server Port (default is 3478) => 3478
    do not change anything else THEN NEXT
    External Number => use the same format VOIPCHEAP has gave you
    Authentication ID => your VoipCheap username
    Authentication Password => your VoipCheap password
    setup your route inbond calls then next
    finish or setup a prefix for your line.
  3. tazz
    tazz New Member
    Sep 12, 2007
    124
    Alright thanx
    Thats very kind of you. Thanks much...............
