VOIP-Client catch all outgoning calls
Discussion in 'Android' started by joachimgr, Jul 12, 2013.
  1. joachimgr
    Dec 11, 2009
    I've installed the Android-client on a Samsung Note II. The Problem: Every outgoing call I make is handled by the 3CX-Client. No matter how I set the option "Redirect normal call" under Settings- Integration. Any hint?
    Joachim
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi Joachimgr,
    You can reset the app preferences and you gsm calls will then be handled by the phone's dialler. To do this go to your Note ii settings>>application Manager and hit the option button (left button out of the 3 your note has) and select 'Reset app preferences'. That should be it. Please let me know if this works for you.
