VOIP Client Install - Vista
Discussion in 'Windows' started by tj_12340, Feb 23, 2008.
  1. tj_12340
    Feb 23, 2008
    I have tried to instal the VOIP client several times but keep getting an error when loading the 3CX VOIP Client application.
    The detailed event logs is detailed below, any ideas ?
    Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2008-02-22T18:04:22.000Z" />
    <EventRecordID>16404</EventRecordID>
    <Channel>Application</Channel>
    <Computer>MONPRI</Computer>
    <Security />
    </System>
    - <EventData>
    <Data>3CXVoIPClient.exe</Data>
    <Data>5.1.4132.0</Data>
    <Data>47b40378</Data>
    <Data>kernel32.dll</Data>
    <Data>6.0.6000.16386</Data>
    <Data>4549bd80</Data>
    <Data>e06d7363</Data>
    <Data>0001b09e</Data>
    <Data>588</Data>
    <Data>01c8757d2ba4bdab</Data>
    </EventData>
    </Event>
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Are you using the lateset version, I have the client working fine on a Vista Laptop
    Stephen
  3. tj_12340
    Feb 23, 2008
    yes, using v.4132.
    It worked once but then uninstalled and reinstalled and that's when problem occurred.
  4. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Try ensuring all traces of the client are removed from the registry, then try reinstalling.
    Stephen
