VoIP Client Parameters
Discussion in 'Windows' started by Gao182, Aug 27, 2008.
  1. Gao182
    Aug 27, 2008
    Hi All!
    Anybody knows anything about how can i run the client with parameters?
    Forexample 3CXVoIPClient.exe -dial=sip:Extension
    I think it's possible, because from Outlook we can start a call.
    Waiting your help.
    Gao
  2. Fobbah
    Dec 2, 2008
    I want to know exactly the same thing.. ive tried
    3CXVoIPClient.exe call [number]
    which sort of works but is unusable because the phone number winds up getting corrupted.
    It will try to dial out to a number, but 2 or 3 random digits from the ph no don't wind up getting entered in before dialing, rendering it useless.
    This software is quite good and i want to integrate it with the custom CRM i'm developing, but i can't find any resources on this topic, which is annoying, because they MUST be there somewhere.
    Alternatively, is there some sort of TCP/IP protocol controlling the dialer?
