VoIP Codecs
Discussion in '3CX Phone System - General' started by andymars, Jun 22, 2010.
  1. andymars
    Jan 12, 2010
    47
    Does 3cx or does anyone know of a guide explaining the differences between the widely-available VoIP codecs?
    I'm looking in particular at a quality vs bandwidth scale for the following:
    PCMU (u law)
    PCMA (a law)
    G723.1
    G726
    G729
    G722
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    You can find a lot of that information on google just by searching for "VoIP Codecs".
    Here's something i found: http://www.ozvoip.com/voip-codecs/
  3. andymars
    Jan 12, 2010
    47
    Thanks that's one of the best pages i've seen. Any particular recommendations from anyone?
  4. carolinainnovative
    May 4, 2009
    369
    5
    It just depends on what you're looking for...
    If you're low on bandwidth, G729 does a good job for much less bandwidth. If you have the bandwidth, U-LAW/A-LAW are great because they have the best voice clarity.
    I don't know much about the GSM codec but I imagine it is somewhere in the middle between the two.
  5. LeonidasG
    Nov 19, 2008
    1,399
    79
    It's as you said, though personally i hate the GSM Codec as whenever i use it, it simply sounds awful compared to everything else.
