VOIP for Blocked Countries
Discussion in 'Windows' started by qa1, Oct 19, 2010.
  1. qa1
    qa1
    Jul 28, 2010
    6
    Hi all ,
    there is a complete solutions for using voip in countries where voip is blocked. the most important is with 3cx so 3cx is offering tunneling option for doing so ,
    there are some other ways doing the same, like VPN ,
    any one have any other solutions to the block area and it should be legal
    10,366
    227
    VPN and the tunnel option may get around the standard VoIP ports being blocked. However, the ISP's/Governments doing the blocking are well aware of the methods used to by-pass their blocking. So...it may work, or it may not. the only way to tell is to try. One "service" that I looked into in the past, and i believe it is used to "get around" the blockages put up by some countries , is iPig. http://www.iopus.com/ipig/ If all else fail, that might work.
