voip gateway as voipwise.com
Discussion in '3CX Phone System - General' started by mademirci, Jul 1, 2008.
  1. mademirci
    Jul 1, 2008
    Using free edition of 3CX System,
    I have added sip.voipwise.com as Voip line to 3CX, at the main line status it say its registered but i can not make call from the same computer via 3cx client software. 3CX Voip Client connects to Server but when try to call somewhere it directly gives "Forbidden" error on the status line
    And when i check the server it gives the error below, any ideas?
    20:15:30.473 Call::Terminate [CM503008]: Call(26): Call is terminated
    20:15:30.473 CallCtrl::eek:nIncomingCall [CM502001]: Source info: From: 26; To: "3CXPhone"[sip:111@localhost:5060];tag=575b0d64[sip:2@localhost:5060]
    20:15:30.473 CallCtrl::eek:nIncomingCall [CM503013]: Call(26): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 2@localhost:5060 tid=3b19c44f66220069 cseq=INVITE contact=111@127.0.0.1:5070 / 2 from(wire)
    20:15:29.654 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:2@localhost:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5070;branch=z9hG4bK-d8754z-2c5cfe38d72c004e-1---d8754z-;rport=5070
    Max-Forwards: 70
    Contact: [sip:111@127.0.0.1:5070]
    To: [sip:2@localhost:5060]
    From: "3CXPhone"[sip:111@localhost:5060];tag=575b0d64
    Call-ID: MTZhZmU4NjEzYTM0NjFmNmZmN2JmOWQ1NTljMjdjZjQ.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Supported: replaces
    User-Agent: 3CX_VoIP_Client
    Content-Length: 0
    20:15:29.654 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 2@localhost:5060 tid=2c5cfe38d72c004e cseq=INVITE contact=111@127.0.0.1:5070 / 1 from(wire)
  2. OZ Boy
    Sep 5, 2007
    I now that I am not helping much, but I have the same problem "Forbidden" calls on external extension, however I could receive calls (local and external).
    Also see "X-Lite external extension - Call Forbidden" topic.
