VoIP-gateway in PSTN <-> SIP mode / incoming from PSTN
Discussion in '3CX Phone System - General' started by VladislavA, Jun 14, 2007.
  1. VladislavA
    Jun 9, 2007
    30
    Recently I tried to use the D-Link DVG-6004S as a VoIP-gateway in PSTN <-> SIP mode.
    I found that internal communications (SIP-phone <-> SIP-phone) is fine but PSTN <->Gateway <->3CXPhoneSystem<->SIP-phone communication is impossible.
    Firstly, I tried troubleshooting PSTN incoming call (PSTN -> Gateway ->3CX_Phone_System -> SIP_Phone). During call initiation 3CX generated server status message
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    PBX just can not associate received SIP INVITE with any known entity. Create PSTN gateway with line that has internal number 10000. And read the manual.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
  4. VladislavA
    Jun 9, 2007
    30
    Yeah, I already have defined "PSTN line" and "VoIP Gateway Configuration".
    Result is the same for default Advanced options and corrected Advanced options.
    I tried two modes (with Hotline and w/o Hotline) with the same result. Then I decided that problem in 3CX.
    Here are the settings for Hotline mode (VoIP gateway web interface):
    * The Telephony settings page.
    Line: 1
    Enable: (checked)
    Type: FXO
    Hot Line: (checked)
    Hot Line No.: 100
    All other settings are by default.
    Here are the settings for "w/o Hotline" mode (VoIP gateway web interface):
    Line: 1
    Enable: (checked)
    Type: FXO
    Hot Line: (unchecked)
    Hot Line No.: (empty)
    In the "w/o Hotline" mode I entered "100" on the deskphone after VoIP gateway voice message.
  5. VladislavA
    Jun 9, 2007
    30
    One man from the forums.d-link.ru forum told me about using D-Link WAN Ethernet interface instead of D-Link LAN interfaces. (Note - I don
