VoIP Gateway naming
Discussion in '3CX Phone System - General' started by kp_odata, May 9, 2007.
  1. kp_odata
    May 7, 2007
    6
    When you name the VoIP Gateway DO NOT USE _ (underscore) in the name - both in the Gateway as well as in 3CX.
    The authentication will fail.
    Krishna
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i thing that is because this is a keyword in the callprossessing
    i suggest that 3cx denie this string or put some info in the form that helps the user not to use this strings
