VOIP gateway recommendation for UK ISDN30
Discussion in '3CX Phone System - General' started by adminbod, Apr 4, 2011.
  1. adminbod
    Jan 18, 2010
    36
    Hi - just wondering if anyone has a recommendation for a hardware VOIP gateway for use with a British Telecoms ISDN30 circuit (30 channels)
    I want to mirror our existing PBX configuration (an old Avaya INDeX) to a 3CX install and then, hopefully, pull the RJ45 out of the INDeX and into the VOIP gateway... never quite as easy it sounds I know, but you get the idea.
    regards,
    Dom
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Hello Dom,
    Patton gateways do seem to be really reliable. I should go for that.
    Kind regards
    Richard
