VoIP Gateway with E1 trunk support?
Discussion in '3CX Phone System - General' started by sonlm, Sep 17, 2007.
  1. sonlm
    Mar 28, 2007
    13
    I have 8 E1 trunk lines. I'm searching for a VoIP Gateway which supports E1 lines (has 8 ports or 16 ports) and be compatible with 3CX.
    Is there anyone can help me?
    Thanks and regards,
    Sonlm
  2. ktikoft
    Jun 22, 2007
    59
    We are running a Quintum Tenor DX 2010 - 2 x E1 10 port unit with the current version of 3cx with no call issues if it helps.
