VoIP Gateway y IP-BPX
Discussion in '3CX Phone System - General' started by serjsk8, Jul 22, 2008.
  1. serjsk8
    Jul 22, 2008
    Hello!
    I have a question regarding VoIP Gateway y IP-BPX.
    I have installed a 3CX Phone System, but I have some doubts regarding the best type of e VoIP Gateway to connect to PSTN lines.
    I have 3 ISDN BRI cables that reach our office from the telephone company´s switch board. Each U-interface enters its NT1 (Network Termination). NT1 transforms U-interface into S/T-interface and connects to IP-BPX Nortel M6501-R.
    Do I hacve to use, for example, a "GrandStream GXW-4108 8-ports Analog FXO" VoIP Gateway and connect to IP-BPX Nortel?
    Or do I need to use, for example, a "Patton SN-4634 3-port ISDN/BRI" VoIP gateway and connect directly to a ISDN BRI U-interface?
    Thank you very much.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Its best to use a Patton ISDN gateway and connect directly to the ISDN trunks and bypass the nortel....
  3. serjsk8
    Jul 22, 2008
    THANKS!!!!
    And I should connect Patton ISDN/BRI to U-interface o connect to S/T-interface ?
  4. Nick Galea
    Jun 6, 2006
    1,994
    304
    Sorry but i dont know what interfaces you are referring to. Follow the Patton config guides and you cant go wrong. If you have a commercial edition with support package, you can also post a support request to our support portal.
  5. serjsk8
    Jul 22, 2008
    Thanks a lot!
