VoIP gateway
Discussion in '3CX Phone System - General' started by David12, Apr 6, 2017.
  1. David12
    Apr 6, 2017
    At the moment I use FreePBX with OpenVox analog card but I am interested in 3CX. I have router with 4 FXS lines. Can I use 3CX with current equipment or I need separate VoIP gateway?
    10,862
    302
    If the OpenVox card is supported by Linux drivers, there there is a chance it will work with the Linux version of 3CX. However...even if there are drivers, it may (probably) still not be "officially" supported by 3CX, which would mean no auto-provisioning.
    You mention FXS, is the OpenVox FXS ports (ATA), or FXO (a gateway?). You may need to clarify.
    #2 leejor, Apr 6, 2017
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    For testing purposes, for the sake of keeping things simple, I would setup a sip trunk between the 3cx and freepbx.
    gorbros likes this.
  4. leejor
    10,862
    302
    It would appear that David12 is replacing the existing PBX but attempting to re-use the hardware.
