VoIP Innovations multiple SIP trunk issue
Discussion in '3CX Phone System - General' started by rmayer, Jan 9, 2017.
  1. rmayer
    Jan 7, 2010
    58
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,407
    458
    Hello @rmayer
    Currently this ability does not exist in 3CX, you can however set the destination for calls while creating the trunks without having to set an additional inbound rule for each one. Will you have additional DID's for each of the 8 trunks?
  3. AravindRavella
    Mar 8, 2017
    How can we set this in V15.5 ?
  4. YiannisH_3CX
    May 10, 2016
    6,407
    458
    @AravindRavella
    When you create a trunk there is a general rule under the trunk settings on where the calls are supposed to be routed. If you have additional DIDs and you do not create inbound rules for those DIDs then calls to these numbers will be routed to the destination under the trunk settings.
  5. accentlogic
    accentlogic New Member
    Nov 14, 2013
    174
    75
    I had one setup this way, and the client complained of an issue where the audio was not connected for a second or two after the call was answered. We added the DID and created a rule, which resolved this. Not sure if this is common, and we did not work with support on it. This was on v15, not sure what release.
