VOIP line calling back
Discussion in '3CX Phone System - General' started by jmatson, Dec 15, 2009.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i noticed today when i called my self from my VOIP line. if i just picked up and hung up. the line will call me back few times until i answer and say something.
    11,094
    327
    I would first off suspect the phone system that thinks you've just done a flash and is still holding the call, trying to remind you that it is still there. If you have a look at the 3CX logs it should show what is happening with the call. What are you trying to do with the call to begin with, do you usually try to call yourself?
  3. Gaetano
    Dec 15, 2009
    Hi. I have the same problem. I get this log event:
    11:07:40.675 [MS105000] C:6.1: No RTP packets were received:remoteAddr=("my ip"):65437,extAddr=("ip pbx"),localAddr=("ip pbx"):9016
  4. gianni
    Aug 27, 2008
    i have the same prolem view this post and the log of test error
    http://www.3cx.com/forums/messagenet-12428.html
