Voip lines not registering after internet connection fails
Discussion in '3CX Phone System - General' started by h2009, Mar 21, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    Hi there,
    After my internet connection failed, i noticed that my VOIP lines are not re registering, until i manually do it myself.
    Is there away around this?
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    What is the sip provider you use
    How much time with out reregistration
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    There is a known issue that exhibits this behaviour, and a fix was implemented via the update mechanism.
    To fire up the update mechanism, click the "Check for Updates" shorcut in the Start Menu Group for the 3CX Phone System.
    After the update is complete, please restart all services, or, better still, restart Windows for the PBX Server.
    Hope this helps.
    Thanks and Regards
    Kevin
  4. h2009
    h2009 Member
    Mar 15, 2008
    447
    hi there thanks for your replies.
    My server software is all updated, which is why I made a post.
    My sip provider is mondotalk UK, and It must have been down for atleast a day. All I had to do was reregister the line and it was fine. I manually took the Internet down, and the server registered it with no problems.
