Voip.ms!
Discussion in '3CX Phone System - General' started by ssss25, Dec 30, 2010.
  1. ssss25
    Jun 24, 2010
    19
    I am new to 3CX server, any help is appreciated.
    I am trying to connect my server to voip.ms, which is my coip provider. I created a "general voip provider" entry under voip providers. I also have a trunk entry.
    3CX server shows me "Registered (idle)" but voip.ms (my voip provider) doesn't show me as registered. I also used wireshark and I didn't see a single packet go outside to register with my provider! So not sure where the 3CX server is getting that idea that I am registered. I used general provider cause I didn't see voip.ms in the list of voip providers.
    Any ideas?
    Thanks,
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please post information how you configured connection to VoIP provider?
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Make sure you select REQUIRE REGISTRATION FOR INCOMING AND OUTGOING. Problem resolved
