VoIP phone Perfectone IP-301
Discussion in 'Windows' started by massimo.chima, Mar 4, 2008.
  1. massimo.chima
    Mar 3, 2008
    I have a problem with voip phone IP-301.
    When I try to make a transfer call, it doesn't work.
    I have upgraded 3CX PBX to the newest version (5.1.4078), but still doesn't work.
    Can anyone help me?
    Thanks in advance
    Massimo
  2. darrellchapman
    Nov 26, 2007
    268
    When does the problem occur? Transferring to the IP-301 or from the IP-301? Also what is the other device? Is it the VoIP Client or some other device?
    One thing I've noticed (and already posted on these forums) is that the all attended transfers to an extension that is using the VoIP Client will fail. Blind transfers work correctly.
    Darrell Chapman
  3. massimo.chima
    Mar 3, 2008
    Hi Darrell
    the problem occur only trasferring call between two IP-301. In some cases the second IP-301 stops working and must be restarted.
    I agree with you for blind and attended transfers.
    Have you any suggestion?
    Massimo
  4. darrellchapman
    Nov 26, 2007
    268
    Unfortunately, I have no idea. However, may I suggest that you look in to upgrading/downgrading the firmware that's currently in your phones? I couldn't find any information on Perfectone phones so I can't tell you how to do this but I would suggest Googling this to see if anyone is having this problem with these phones. If a phone is crashing (to the point of requiring a restart) there is something wrong with the phone.
    Darrell Chapman
  5. paradiseit
    May 26, 2008
    please i need to know if you have find the solution for this problem
