VOIP Phone unable to make calls
Discussion in '3CX Phone System - General' started by gary2seven, Nov 25, 2010.
  1. gary2seven
    Sep 18, 2009
    48
    I have configured a new extension using 3CX Voip Phone on a Windows 7 Laptop. It's a remote worker so I am using 3CX tunnel.
    Extension (206) can recieve calls, but whenever they tray and make a call, the phone says "Forbidden" and 3CX Log show;
    I have another phone with same setup (actually with a worker in Australia!) and that one works fine.
    Any ideas?
    Gary.
    11,096
    328
    Same IP and port...?
  3. gary2seven
    Sep 18, 2009
    48
    Yes, different extension number but everything else the same.
    Gary.
