VOIP provider Authorization code is different from User ID
Discussion in '3CX Phone System - General' started by doronsaar, Aug 26, 2010.
  1. doronsaar
    Aug 26, 2010
    So it's impossible to set it up as a provider in 3CX phone system.
    The voip line works perfectly without any problems on x-lite client program, but no way on 3cx.
    Any Ideas?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    I see you have given up quite easily. Nothing is impossible, 3CX is very flexible and tries to limit nothing. With that in mind and considering your answer is not very long ( please read forum rules on posting). Please see attached screenshot that should relate to your configuration settings.
    If this is not what your looking for please be more clear and I will assist you further.
  3. doronsaar
    Aug 26, 2010
    Thank you,
    I put the authentication ID I have on this outbound SIP field "To: User Part".
    I still get on the server activity log "registration failed .. Cause: 401 Unauthorized."
    When I put the authentication ID in the Authentication ID text box on the "account details", and the phone number in the "To: User Part" sip field, I get the error: "Cause: 404 Not found"
    More info:
    When connecting from a MP202 SIP Adapter, the settings look like this:
    Is there any other place I might be able to put this Authentication ID in?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HI,
    It seems like you are failing at registration stage, therefore calling becomes useless.
    In the VOIP provider settings:
    Authentication ID = CB9823...
    Passowrd: = authenticaion password
    and try and re register.
    At this point if you still can get it to work, I will have to divert you to open up a support ticket at http://support.3cx.com and we will try and set up the voip provider for you and test it ourselves.
  5. doronsaar
    Aug 26, 2010
    I've obviously tried that already.
    3CX simply doesn't have this simple feature of putting a seperate Authentication ID different from the phone number.
    Eventually I had no choice but to install the competitor: Axon.
    http://www.nch.com.au/pbx/index.html
    In Axon there is no such problem, and the registration succeeded.
