VoIP Provider changed s.th. - cannot make calls
Discussion in '3CX Phone System - General' started by Tugi2o, Jul 14, 2010.
  1. Tugi2o
    Feb 20, 2007
    61
    i think my german voip provider (ARCOR bought by VODAFONE) made some changes - now it is not possible to use the 10 VoIP-lines with 3CX. So i have a lot of problems.
    If i use ths soft phone from my provider everything is working. if i use with 3cx phone system / assistant / phone i cannot make calls :(
    On their software i have to write down phone number & password and also online username and online pasword.
    so i think it has to do something with these settings? is this possible?
    i can send the developers the account data to make some tests - if they are interested to solve this problem - i hope they are.
    please tell me what i have to do. thanks.
    Tugi
  2. carolinainnovative
    May 4, 2009
    369
    6
    Start by reading this post, put your pbx in verbose logging mode and post logs. See here:
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
