Voip Provider Configuration
Discussion in '3CX Phone System - General' started by Anonymous, Aug 31, 2006.
  1. Anonymous
    Anonymous Guest
    How to configure a Voip Account if the outband proxy and port is diff than the sip proxy !
    And how could we personnalize pbx config ( ports etc )
    thx
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    We are making amendments and the next beta which should be released shortly is going to have configurable ports amongst other requested features. Thank you for your time and feed back!
  3. Anonymous
    Anonymous Guest
    Hope the next beta would not take time !
    Hi !
    if i could help you for alpha test make sign !
    thanks
