Voip Provider - Enable / Disable single Provider instead of All
Discussion in 'Ideas' started by patrick.leemans@xs2t, Mar 3, 2016.
  1. patrick.leemans@xs2t
    Jun 9, 2009
    5
    Missing Feature:
    VoIP Providers -> Enable/Disable on provider instead of all of them + Show status in Port Trunk Status view.
    This will allow you to better troubleshoot a mal configuration of a VoIP Provider Line and you can only enable and disable this provider which config needs to be adapted.
    Thanks,
    Patrick
