VoIP Provider Fail Over Facility
Discussion in '3CX Phone System - General' started by simonhc, Jun 27, 2014.
  1. simonhc
    Dec 9, 2011
    41
    I am currently experiencing problems with my current VoIP provider and was wondering if 3cx had any faoil over facility for VoIP providers.
    The idea being that if one provider failed for whatever reason, 3cx would use the other VoIP provider.
    Thanks in advance
    Simon
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You can register more than one VoIP provider wtih 3cx, so if one fails you will automally youu be able to utilize teh fail over trunk
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    the issue will be that playing one provider with or against another is .......who has your numbers? while you might be able to have your numbers forwarded to the other and vice versa, try and find a provider that internally has the capability to shift from one site to another.
  4. lneblett
    Sep 7, 2010
    2,061
    56
  5. jpillow
    Jun 20, 2011
    1,342
    @ineblett a large of amount of ITSPs allow you to register a trunk at more than one location, however if that trunk goes down at one location due to an issue on the internet going out it will go down at all locations so there is no actual redundancy in that scenario.
  6. lneblett
    Sep 7, 2010
    2,061
    56
    JP,
    I took the issue as being "experiencing problems with my current VoIP provider". What those problems are I do not know. However, I do think that most providers will attempt to resolve the issues if at all possible and that more of the larger providers have more than one center so that if problems arise at one location, then switching to the other center might offer relief. It simply depends on what the issue is and the problem was not fully defined.
    I did not know if his current provider is one that employs multiple sites or not, but thought I would mention it so that he could explore the option and failing that, perhaps seek out a new provider.
