VoIP Provider Fail Over Facility
Discussion in '3CX Phone System - General' started by simonhc, Jun 27, 2014.
  1. simonhc
    Dec 9, 2011
    41
    I am currently experiencing problems with my current VoIP provider and was wondering if 3cx had any faoil over facility for VoIP providers.
    The idea being that if one provider failed for whatever reason, 3cx would use the other VoIP provider.
    Thanks in advance
    Simon
    10,375
    231
    As it stands, your second provider can be put in as second choice in the outbound rules. If registration fails, on the first, or the first group is "all trunks busy", then calls would use the second. Unfortunately, incoming isn't so easy. A failure would require that your "failed" provider can send (forward) calls to another number on a different provider.
  3. simonhc
    Dec 9, 2011
    41
    Hi Leejor,
    Thanks for explaining that. That is exactly what I was hoping for...
    Simon
  4. simonhc
    Dec 9, 2011
    41
    Hi Leejor,
    Simon
