Voip Provider G729
Discussion in '3CX Phone System - General' started by amygoda, Jul 30, 2008.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Do you know which voip provider using codec G729
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello all
    me also wants to know the VOIP providers codecs
    Thank you
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    I believe you would be hard done by if you could find any voip provider that doesn't support it. But remember inorder to use it, you need to buy a license from 3CX, then it will appear in the codec list.
  4. francesco
    francesco New Member
    Jun 23, 2008
    102
    in the last version g729 is free
  5. Anonymous
    Anonymous Guest
    Can you please clarify this? The G729 codec is not free.
  6. DanielMonsieux
    Feb 25, 2008
    6
    Weepee-voip.org
    They use almost every codec.
    Only not supported is iLBC
    Daniel
