voip provider in usa
Discussion in '3CX Phone System - General' started by Anonymous, Oct 6, 2006.
  1. Anonymous
    Anonymous Guest
    does anyone know of a isp in the usa that meets the requirement for 3cx pbx. My current isp will not work with 3cx. Or maybe someone knows another software, softphone that will identify the did# that is ringing in.
    I need someway to be able to have the did# be identified and may work with outlool contacts or another contact database. thanks
