Voip Provider Incoming Calls
Discussion in '3CX Phone System - General' started by gerdk, Dec 22, 2007.
  1. gerdk
    Dec 22, 2007
    10
    Hello all!
    I buyed the SBS Version of 3CX! Sometimes all incoming calls works fine and sometimes nothing works! Im from Austria and my Service Provider (UPC Austria) told me that this Software should work without Problems! What can i do that this PBX works permanently? :lol:
    First Error:
    Calling Extension directly from outside!
    http://www.3cx.com/support/source-identification-err-2.html
    I follow this Guide but it doesnt help!
    If i restart, it works for an Hour than it stops working!
    Second Problem is the Fax:
    I got a normlay Faxdevice connected on a Grandstream Handytone 286!
    For Example Extension Number 15 (i have to call directly from outside)
    Guys im not a PRO on this Software i need your help!
    Thanks for any Answers!
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Hi please give us some more informations about your configuration:
    Version of 3cx
    used phones
    and if you say after a hour it stops working
    is there no activity in server status log ?
    or does only the phones not ring ? (if only the phones not ring it can be a problem with the phones.)
    i think we can identify what the problem is and then you can enjoy it :)
    btw i am german and possible you want some help in german?
    Andy
  3. gerdk
    Dec 22, 2007
    10
    Hi Andy!
    Thanks for the quick answer! German would be good because my english not the best! :D But i will try to continue speak english here so most of the people can understand me! :D
    My Configuration:
    Voip Provider - Sip Server with Username (my Phone Number) and Password! (Status is green Registered)
    I build a Seperate Network for Voip!
    Router = Linksys BEFSR41 (Offical IP Adress) Forwarded required Ports to 3CX PC! The Firewall Test is 100% OK!
    One PC with Windows XP Sp2 with 3CX Software V5 3752.0installed! This PC didnt have a connection to others PC! I dont want use Software Phones! I only want to use the Digital Receptionist, Fax (Route to Email if Possible with Voip Provider) and 1 Extension! I create 2 DID/DDI numbers one for my old Fax Device (connected to Grandstream Handytone 286) so i can reach the Fax directly from outside! (work sometimes sometimes not) and one for an old Phone (connected to Grandstream Handytone 286 too)!
    Server Log File:
    [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:000myNumber+extension@myip:5060;rinstance=200fe83c32694146 SIP/2.0
    Via: SIP/2.0/UDP 212.41.xxx.xxx;branch=z9hG4bKa2f.31d6d8b1.0
    Via: SIP/2.0/UDP 172.29.183.11;rport=5060;branch=z9hG4bKa2f.cffdc9c2.0
    Via: SIP/2.0/UDP 172.29.183.108:5062;branch=z9hG4bK14afb4761
    Max-Forwards: 69
    Record-Route: [sip:212.41.xxx.xxx;r2=on;lr=on;ftag=a5cc386e37f8073]
    Record-Route: [sip:172.29.183.10;r2=on;lr=on;ftag=a5cc386e37f8073]
    Record-Route: [sip:172.29.183.11;lr=on;ftag=a5cc386e37f8073]
    Contact: [sip:069911717049@172.29.183.108:5062]
    To: [sip:042mynumber@p1.provider.at]
    From: [sip:externalnumber@p9.voip.inode.at];tag=a5cc386e37f8073
    Call-ID: 388721975b8850613192efe66aaca5df@p9.provider.at
    CSeq: 467512832 INVITE
    Session-Expires: 600
    Supported: timer, replaces
    User-Agent: Patton SN2400 MxSF v3.2.8.45 00A0BA01DDD4 R3.21 2007-05-14 H323 SIP
    P-Preferred-Identity: [sip:externalnumber@172.29.183.108]
    Content-Length: 0
    CM302001]: Authorization system can not identify source of: SipReq: INVITE 042mynumber@myip:5060 tid=a2f.31d6d8b1.0 cseq=INVITE contact=069911717049@172.29.183.108:5062 / 467512832 from(wire)
    (for Security Reason i dont want show numbers and IPs)
    Thank you for your help!
    Gerd
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Is your IP from the ISP dynamic? I have a client that this happens to because for some reason the IP changes and the registration doesn't work until they reboot.
    I'm switching them to a static IP next week.
  5. gerdk
    Dec 22, 2007
    10
    Hello Rob!
    No my IP is Static!
  6. gerdk
    Dec 22, 2007
    10
    Hello Guys!
    Going back to Version 3! All works fine now since 5 hours! For what i bought this SBS License of 3CX is to route Faxes as PDF 2 Mail. I only have 1 traditional Fax Device and 1 Telephone. I hope the coming versions of 3CX will fix this Bugs.
    I got one Problem to receive fax on the Grandstream Handytone 286! (traditional Fax Device ist connected)
    The Fax device is trying to get the Fax but i get an error on Display!
    It says abortet. On the Serverlog it says "Call is terminated"
    I hope someone can help me on this issue!
    Thanks a lot!
    Gerd
  7. silentfun
    silentfun Member
    Dec 11, 2006
    364
    yes your log state Unidentified incoming call
    i think best would be try to use a secon probider to identify if that is a provide specific problem or a general problem. this would help to minimize the time for solving this problem.
    if you like i can give you a account from a supported german voip provider (sipgate.de) for some time. then we can see if that is also not running for incomming calls after a hour.
    i have a problem with one extension a hardware phone that have ever run but since some time it dont ring (even it is green) but if i restart it run again (atm i try to find out after how much time it is unreachable to find out where it comes from)
    so you see it is a bit detective work but it also gives a deep knowlege about this system and gives also some new chances.
    Andy
  8. silentfun
    silentfun Member
    Dec 11, 2006
    364
    you can try to play a bit around with the diferent codecs (best u use a codec with high quality
    you can also try to enable the Error correction on your fax that increase a the time but sometimes help.
    you can also decrease the speed from your fax to next lower speed
    14400 > 9600 > 2400 (or if there is a oversee option this is wort also a try)
    Andy
  9. gerdk
    Dec 22, 2007
    10
    Hello Andy!
    Thx for your Answer! I called my Provider before i post here, they told that some customers using this Software without Problems and they told me they will check my configuration again! I tried today to send faxes to myself! (http://www.faxonline.de) Sometimes works sometimes not! Maybe its the testserver from http://www.faxonline.de! I will test it next week from a company! But phone things works like a charm! But why it dont work in Version 5?
    Thanks Andy!
    Gerd
  10. gerdk
    Dec 22, 2007
    10
    I will try it!!
    Thank you very much!
  11. silentfun
    silentfun Member
    Dec 11, 2006
    364
    I can send you some fax also if that helps you.
    i can send it via
    - classic analog fax over isdn pbx
    - classic fax over analog
    - computerfax via faxserver from sipgate fax server (it works as a printer driver)
    you can call me 0049211580098012 (international) or 0211580098012 (national) it is standart germany no premium number
    Andy
  12. gerdk
    Dec 22, 2007
    10
    Hello Andy!
    You want me to call you today? (its Sunday :lol: )
    Thanks Andy :D
    Gerd
  13. gerdk
    Dec 22, 2007
    10
    we can also communicate over MSN if you have!
    My Adress to add is:
    gerd.kleindienst@hotmail.com
    Cheers
    :D
    Gerd
  14. gerdk
    Dec 22, 2007
    10
    Skype will also help :lol:
    Skype Name: lansolutions4you
    Gerd
  15. gerdk
    Dec 22, 2007
    10
    Version 3 with help from Silentfun works like a charm now!! (Fax included)
    Thanks a lot!!!
    Sorry but for me Version 5 isn´t good at all!
    I wish all People a Merry Christmas and a Happy new Year!!!! :D
    Cheers
    Gerd
