VoIP provider with no auth
Discussion in '3CX Phone System - General' started by extrascope, Apr 19, 2012.
  1. extrascope
    Jan 31, 2010
    I am trying to configure our VoIP provider on our new 3cx install. However, whether I select generic sip trunk or generic VoIP provider, I am still asked to enter authentication details. Our provider does not require authentication. Please help.
    11,082
    324
    It might help if you posted the name of the provider, as someone on the forum may also use the same company.
    Most providers require security of some sort, even if registrations isn't a requirement. That might be your fixed IP, or simply your user name (number), along with a password.
    You may try filling in the "required" spaces with redundant data. If it isn't used by your provider, it may just be ignored.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    I put some values because I must, and after that when i created Generic sip trunk/provider under the "Voip providers" I select that voip provider and click "advanced tab" and under "Require registration for:" -> do not require
  4. willow
    willow Member
    Mar 1, 2011
    471
    just put anything in there and then set the trunk to authentication not required for calls
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    doesn't matter what you put in to authenticate you can simply set "authentication not required for calls"
  6. extrascope
    Jan 31, 2010
    Thanks for the help guys. I will test and report back. The provider is gamma.
