voip providers registration error with version 12
Discussion in '3CX Phone System - General' started by giorgiobusoni, Sep 11, 2013.
  1. giorgiobusoni
    Apr 6, 2011
    32
    since I update to version 12, voip providers start failing to registrate continuously a short time after the start of the server.
    I user messagenet and ehiweb.it as providers.
    I wrot to both tecnical supports, despite the fact that both errors started 1 hour right after upgrading to version 12, and so I think the problem is due to 3cx, not them.
    Here is the answer from messagenet support (italian):
    and google translation:
    How to fix this problem?
  2. jed
    jed New Member
    Feb 1, 2010
    138
    41
    Did you by any change select the HTTPS option when installing your 3CX server?
    - or did you install on s server where this option was selected (eg from a beta release of v12)
    There might be a problem by this, which is reportet to 3CX Support, and now passed on to the Development team.
    In my case the V12 was registrating several times at the SIP provider.
    /Jesper
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    This issue is known to 3CX as we reported it last week. its currently with the developers to work on a fix.
  4. giorgiobusoni
    Apr 6, 2011
    32
    is there any workaround in the meantime?
    How mich time for the fix, approximately?
    1 day?
    1 week?
    1 month?
    many months?
  5. davidbenwell
    Apr 27, 2010
    704
    The QA team has provided me with a patch for the 3CXPhoneSystem.exe file which is inside the path: C:\Program Files\3CX PhoneSystem\Bin
    PLEASE NOTE that this patch has NOT gone through any tests except for the multiple registration issue, so be aware that it may not necessarily be adequate for production use, and also make sure you retain the previous version of the file before replacing it should you choose to implement it.
    You can download the patch here: http://www.3cx.com/downloads/v120/support/64bit/3CXPhoneSystem.exe
    Note also that this patch can only by applied to a 64-bit system.
  6. AdvancedDistribution
    Sep 11, 2013
    We're having a similar issue. We just upgraded one of our facilities to V12 yesterday morning (we have 4 servers currently, 3 remain on v11)
    We have bridges that are setup between our facilities and they've been working fine on V11.
    Several hours after the upgrade to V12, the bridges that this building connects to have been constantly losing registration.
    It then fails to re-register "Call or Registration to A/ B has failed. sip:20003@xxx.xxx.xxx.xxx:5060 replied: 407 Proxy Authentication Required"
    Several minutes later, the registration will succeed.
    It will do this 2-3 times every hour, with the bridge being down at minimum 5minutes per incident.
    It seems that the bridges where this server is the "slave" are the ones that fail. The one bridge where this is the "master" has not had issues.
    We're running Windows 7 32bit..Is there a patch for the 32bit version that resolves this?
