VoIP Questions - Gateway/ Codecs/ Phones
Discussion in '3CX Phone System - General' started by shuey227, Aug 1, 2007.
  1. shuey227
    Aug 1, 2007
    14
    I looked for the following information but could only find bits and pieces scattered all around.
    I am looking to setup a VoIP system for a small business, with 3 or 4 phones and 3 or 4 lines. I setup 3cx on a Win2k3 server, using Grandstream 2000 phones, and Broadvoice as the carrier. It all works however the quality is quite poor for business purposes.
    I am using the GSM codec on the phone, but looking on Broadvoice's website they only support G711u, and in the future G726-32 at 32kbps and G729a at 8kbps. My calls are taking between 60 - 80 Kbps, so from what I've read that isn't GSM, which is supposed to be around 20 Kbps.
    Here are my question:
    a) What is the best codec to use for 3-4 lines on a DSL line? Low bandwidth and decent quality...
    b) What VoIP carrier uses those codecs? Which ones are the best (USA New York)
    c) Will the Grandstream 2000 support those codecs? If not, which phones do I need to get?
    Thanks for your help!
    Dale
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    check this thread http://www.3cx.com/forums/viewtopic.php?t=1902&start=0&postdays=0&postorder=asc&highlight=
    There are answers for your questions regarding bandwidth.
  3. shuey227
    Aug 1, 2007
    14
    i read that forum, but only answers part of the question.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    I would suggest you to try direct connection from Grandstream (or softphone) to Broadvoice. It may happen that voice quality is not a problem of PBX, but Broadvoice itself, or your DSL link. Also, in Grandstream settings you can change priorities of codecs to find the best one.
  5. shuey227
    Aug 1, 2007
    14
    apparently broadvoice only G711u, which isn't an option on the phone. the options in the phone are:
    GSM
    G.723.1
    G.729A/B
    PCMU
    PCMA
    G.726-32
    G.722 (WIDEBAND)
    iLBC
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    it is G711
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    G.711u is exactly PCMU :)
    Anyway, even if Broadvoice supports only PCMU - it worth to try direct connection from Grandstream. If quality of direct call is better that thru PBX - let us know, and we could try to tweak your settings :)
  8. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    As SY and Archie already said before,
    G711u=PCMU and
    G711a=PCMA
    they are the same thing. Just a different name for them...
  9. shuey227
    Aug 1, 2007
    14
    thanks for your help.
    next question - i am looking for 3-4 lines (let's go with 4 for this case) and looking for a voip provider (New York) but want to use the same outbound caller ID for all calls. when i contacted broadvoice they had said i would need 4 lines. is there a provider that can handle 4 calls on one line, or perhaps use the same caller ID?
    thanks for all your help
  10. AndrewRTS
    Aug 8, 2007
    39
    Hey shuey...
    You might want to try Junction Networks:
    http://www.junctionnetworks.com
    I've been very impressed with them and the call quality has been spectacular. I have only set them up so far as outgoing, as I'm waiting on my regional DID numbers to port, but on outgoing it's perfect with 3CX.
  11. shuey227
    Aug 1, 2007
    14
    thanks for the info. should i be looking at the sip hosting?
    shuey
  12. AndrewRTS
    Aug 8, 2007
    39
    I just signed up for the PSTN gateway. That was the closest to a traditional "phone line". I just received the authorization form to get my numbers ported. Yeah!
    Their support has been spectacular, and I had the outgoing calls working in about 3 minutes on 3CX.
  13. shuey227
    Aug 1, 2007
    14
    echo cancellation
    i'm trying a variety of voip providers and every once in a while i seem to get choppy or an echo. how can i solve the choppy echo?
    thanks!
  14. SY
    3CX Support
    Jan 26, 2007
    1,825
    Re: echo cancellation
    If you hear yourself with delay then it is not related to 3CX PBX.
    Regards
