VoIp Setup
Discussion in '3CX Phone System - General' started by Carlos Sosa, Feb 21, 2017.
  1. Carlos Sosa
    Feb 21, 2017
    I'm really new to the whole VoIP Thing. I'm currently remodeling a new main office in Caracas Venezuela for my company. In my main office I will have 5 Land (Regular-Analog) Phone Lines. What I would like to do is set up a VoIP System that uses my 5 Regular Land lines. I also would like to be able to setup additional offices and use the same VoIp System on all of them. Can I use 3CX for this and where can I find a guide to setup something like this.
    In help/guidance would be greatly appreciated.
    Carlos Sosa
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Carlos Sosa
    Assuming that the PBX will be in the same network as the analog phones then you can use an FXS device to connect the phones to the PBX. Basically an FXS device is a device that allows you to connect analog devices to the PBX. Below is a list of supported devices by the PBX.
    https://www.3cx.com/voip-gateways/
    You can then connect multiple remote locations either using remote extensions or bridges depending on your needs and the size of the remote sites.
    You can find more information by reading the admin guide found here: https://www.3cx.com/docs/manual/
    Regarding configuring remote extensions you can find more info here : https://www.3cx.com/3cxacademy/videos/intermediate/
    and https://www.3cx.com/blog/docs/provisioning-a-remote-extension/
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Lost in translation? Maybe OP can confirm that intention is to use PSTN?:confused:
    [​IMG]
