voip skype Currently active calls [none] busy tone -solved
clonick
Hi experts!!
I was setup the 3cx pbx for only incoming calls using skype voip SIP profile, i have 2 online numbers and when u call to one or other, it rings on one extension... all was working fine! but after a masive turn off the light, the server restarted and then when you call to the numbers it rings only one time and then the tone is busy.....
in the activity log in verbose mode, only shows the text: Currently active calls [none]
I'm trying to fix it but i don't have idea what is! the 2 lines are registered correctly using in SOURCE ID: Request Line URI : User Part -> LineID internal number line
also asigned the full number if the DID lines (with area code, national code, number).
as I say, it was working perfectly for a few hours and from nothing it stat sing like a busy tone... my SIP lines work properfly cuz i was testes again directly using x-lite, so is somthing in the configuration......
any suggestion?
thanks
Re: voip skype sip Currently active calls [none] busy tone
Can you post the entire log showing the incoming call (start to finish). Looking at a line or two doesn't give the big picture.
I think the problem could be an error realtioned with 401 or 407 cuz it is showing in the log, but i don't have idea of how to solve it, also we aren't using any proxy server and mastervoip.no-ip.org is a ddns of our ip
NOTE: the ddns, the user skype acces and IP was modify for anonimity in this log.....
ok, the activity log in verbose mode only shows:
16:00:43.347|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:01:15.348|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:01:45.350|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:02:17.352|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:02:49.354|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:03:21.356|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:03:53.359|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:04:25.360|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:04:57.362|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
16:05:29.364|.\Call.cpp(48)|Log5||??:Currently active calls [none]<br>
each print corresponds to one incoming call than when it sounds like a ring (from whose calling), next it sounds busy tone.
and the 3CXPhoneSystem.trace.log files shows this.......
Code:
16:09:07.378|.\Call.cpp(48)|Log5||??:Currently active calls [none]
16:09:07.943|.\RegistrarDB.cpp(305)|Trace5||RegistrarDB::getAllContactIds:There's 27 contact(s) registered
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=d0ea400c6faef20a; expires in 279
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=1e5c7674e310f02b; expires in 279
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=bcb2c750b435d835; expires in 279
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=7b7e1471a7d36d56; expires in 280
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=10d60c21a58c1d02; expires in 279
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=783887833ab6ed92; expires in 280
16:09:07.943|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=a896d0031e0794c4; expires in 279
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=32f582c9dc914162; expires in 289
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=5e2ae4b27d522892; expires in 280
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:5488; expires in 96
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:5100;user=phone; expires in 333
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=27bfa90cc80741d9; expires in 289
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=9548e2fe83b17d3c; expires in 289
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=1d2da71bf43c0737; expires in 289
16:09:07.944|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=c9b8c5d0e57ceb2c; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=69a7c3604675f8a9; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=71bed7fd37f5c94c; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=4de93dc5aa505c66; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=0347b5ffa113ba9f; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=4cdd34279a0678ed; expires in 280
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=69e971c725bc31c2; expires in 279
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=cc31634186d93af5; expires in 280
16:09:07.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=a859b927a8376531; expires in 289
16:09:07.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:52113;rinstance=b8949f572af0e859; expires in 29
16:09:07.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=72ace2a26aa89512; expires in 279
16:09:07.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=73caef594d481bf8; expires in 279
16:09:07.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=6bd1becbde949030; expires in 289
16:09:15.485|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:18.148|.\ClientRegistration.cxx(279)|Trace5|Resip|::ResipLogger:requesting refresh of ClientRegistration sip:[email protected]:5060
16:09:18.148|.\ClientAuthManager.cxx(319)|Debug8|Resip|::ResipLogger: Add auth, 03B4D708 in response to: Digest realm="sip.skype.com",nonce="4f95c4f300003faddd5ba871de09a589c6618cdca29fe028",stale=true,algorithm=MD5
16:09:18.148|.\ClientAuthManager.cxx(344)|Debug8|Resip|::ResipLogger:ClientAuthManager::RealmState::addAuthentication, proxy: 0 Digest username="6551000115069",realm="sip.skype.com",nonce="4f95c4f300003faddd5ba871de09a589c6618cdca29fe028",uri="sip:sip.skype.com:5060",response="cf0e01425c70d9b00ca6989286bd2d9b",algorithm=MD5
16:09:18.148|.\DialogUsageManager.cxx(866)|Debug8|Resip|::ResipLogger:SEND:
REGISTER sip:sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-f671d558417fdb5c-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060;rinstance=6a250f847867869e>
To: <sip:[email protected]:5060>
Call-ID: Nzk1NWU2MDEzMTgyODVlMmM3YmRhMDcwODUxOWUwMGE.
CSeq: 29 REGISTER
Expires: 60
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhoneSystem 10.0.22539.0
Authorization: Digest username="6551000115069",realm="sip.skype.com",nonce="4f95c4f300003faddd5ba871de09a589c6618cdca29fe028",uri="sip:sip.skype.com:5060",response="cf0e01425c70d9b00ca6989286bd2d9b",algorithm=MD5
Content-Length: 0
16:09:18.148|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: Nzk1NWU2MDEzMTgyODVlMmM3YmRhMDcwODUxOWUwMGE.-0d33323e-
16:09:18.148|.\DialogUsageManager.cxx(999)|Debug8|Resip|::ResipLogger:Send: SipReq:  REGISTER sip.skype.com:5060 tid=f671d558417fdb5c cseq=REGISTER [email protected]:5060 / 29 from(tu)
16:09:18.149|.\SipStack.cxx(314)|Debug8|Resip|::ResipLogger:SEND: SipReq:  REGISTER sip.skype.com:5060 tid=f671d558417fdb5c cseq=REGISTER [email protected]:5060 / 29 from(tu)
16:09:18.248|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer F tid=f671d558417fdb5c ms=32000
16:09:18.248|.\DnsResult.cxx(214)|Debug8|Resip|::ResipLogger:DnsResult::lookup sip:[email protected];transport=UDP
16:09:18.248|.\dns\DnsStub.cxx(65)|Debug8|Resip|::ResipLogger:_sip._udp.sip.skype.com (SRV) --> p=0 w=0 1.sip.skype.com:5060_sip._udp.sip.skype.com (SRV) --> p=1 w=0 2.sip.skype.com:5060
16:09:18.248|.\dns\DnsStub.cxx(47)|Debug8|Resip|::ResipLogger:1.sip.skype.com(A)--> 63.209.144.201
16:09:18.248|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer E1 tid=f671d558417fdb5c ms=500
16:09:18.252|.\TransportSelector.cxx(562)|Debug8|Resip|::ResipLogger:Looked up source for destination: [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ] -> [ V4 192.168.15.25:0 UDP target domain=sip.skype.com mFlowKey=0 ] sent-by= sent-port=0
16:09:18.252|.\TransportSelector.cxx(1107)|Debug8|Resip|::ResipLogger:findTransportBySource([ V4 192.168.15.25:0 UDP target domain=sip.skype.com mFlowKey=0 ])
16:09:18.252|.\TransportSelector.cxx(1208)|Debug8|Resip|::ResipLogger:findTransport (any port, specific interface) => Transport: [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ] on 192.168.15.25
16:09:18.253|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=sip.skype.com mFlowKey=0 ]
Via: SIP/2.0/UDP 192.168.15.25:5060;branch=z9hG4bK-d8754z-f671d558417fdb5c-1---d8754z-;rport
Max-Forwards: 70
CSeq: 29 REGISTER
Expires: 60
Supported: replaces
Content-Length: 0
16:09:18.253|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ]
16:09:18.484|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 63.209.144.201:5060 UDP target domain=unspecified mFlowKey=852 ]
16:09:18.484|.\DnsResult.cxx(206)|Debug8|Resip|::ResipLogger:Whitelisting _sip._udp.sip.skype.com(33): 1.sip.skype.com:5060
16:09:18.484|.\dns\RRVip.cxx(129)|Debug8|Resip|::ResipLogger:updating an existing vip: 1.sip.skype.com:5060 with 1.sip.skype.com:5060
16:09:18.485|.\DnsResult.cxx(206)|Debug8|Resip|::ResipLogger:Whitelisting sip.skype.com(1): 63.209.144.201
16:09:18.485|.\dns\RRVip.cxx(129)|Debug8|Resip|::ResipLogger:updating an existing vip: 63.209.144.201 with 63.209.144.201
16:09:18.485|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
[b]
SIP/2.0 401 Unauthorized[/b]
Via: SIP/2.0/UDP 192.168.15.25:5060;branch=z9hG4bK-d8754z-f671d558417fdb5c-1---d8754z-;rport=5060;received=200.33.148.100
To: <sip:[email protected]:5060>;tag=c97b4d1cb1f3d0da549e06a8d482ef63.1950
CSeq: 29 REGISTER
Server: OpenSIPS
WWW-Authenticate: Digest realm="sip.skype.com", nonce="4f95c51c0000438e6765c17158c855ea74a29fc356711c90", stale=true, algorithm=MD5
Content-Length: 0
16:09:18.485|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer K tid=f671d558417fdb5c ms=5000
16:09:18.485|.\DialogUsageManager.cxx(1333)|Trace5|Resip|::ResipLogger:Got: SipResp: 401 tid=f671d558417fdb5c cseq=REGISTER / 29 from(wire)
16:09:18.485|.\DialogUsageManager.cxx(1841)|Debug8|Resip|::ResipLogger:DialogUsageManager::processResponse:
16:09:18.485|.\UserProfile.cxx(158)|Debug8|Resip|::ResipLogger:Found credential for realm: realm=3CXPhoneSystem user=65510001150693CXPhoneSystem
16:09:18.486|.\UserProfile.cxx(135)|Debug8|Resip|::ResipLogger:Adding credential: realm=sip.skype.com user=6551000115069
16:09:18.486|.\ClientAuthManager.cxx(224)|Debug8|Resip|::ResipLogger:ClientAuthManager::RealmState::handleAuth: 03B4D708 Digest realm="sip.skype.com",nonce="4f95c51c0000438e6765c17158c855ea74a29fc356711c90",stale=true,algorithm=MD5 is proxy: 0
16:09:18.486|.\ClientAuthManager.cxx(198)|Debug8|Resip|::ResipLogger:ClientAuthManager::RealmState::transition from cached to current
16:09:18.486|.\UserProfile.cxx(158)|Debug8|Resip|::ResipLogger:Found credential for realm: realm=sip.skype.com user=6551000115069sip.skype.com
16:09:18.486|.\ClientAuthManager.cxx(63)|Debug8|Resip|::ResipLogger:Produced response to digest challenge for UserProfile: <sip:[email protected]:5060>[realm=3CXPhoneSystem user=6551000115069, realm=sip.skype.com user=6551000115069]
16:09:18.486|.\DialogSet.cxx(253)|Debug8|Resip|::ResipLogger:about to re-send request with digest credentials
16:09:18.486|.\ClientAuthManager.cxx(319)|Debug8|Resip|::ResipLogger: Add auth, 03B4D708 in response to: Digest realm="sip.skype.com",nonce="4f95c51c0000438e6765c17158c855ea74a29fc356711c90",stale=true,algorithm=MD5
16:09:18.487|.\ClientAuthManager.cxx(344)|Debug8|Resip|::ResipLogger:ClientAuthManager::RealmState::addAuthentication, proxy: 0 Digest username="6551000115069",realm="sip.skype.com",nonce="4f95c51c0000438e6765c17158c855ea74a29fc356711c90",uri="sip:sip.skype.com:5060",response="49cae829315887ff021627c90085b8cc",algorithm=MD5
16:09:18.487|.\DialogUsageManager.cxx(866)|Debug8|Resip|::ResipLogger:SEND:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-6b6afe1c1641e82d-1---d8754z-;rport
Max-Forwards: 70
CSeq: 30 REGISTER
Expires: 60
Supported: replaces
Authorization: Digest username="6551000115069",realm="sip.skype.com",nonce="4f95c51c0000438e6765c17158c855ea74a29fc356711c90",uri="sip:sip.skype.com:5060",response="49cae829315887ff021627c90085b8cc",algorithm=MD5
Content-Length: 0
16:09:18.487|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: Nzk1NWU2MDEzMTgyODVlMmM3YmRhMDcwODUxOWUwMGE.-0d33323e-
16:09:18.487|.\DialogUsageManager.cxx(999)|Debug8|Resip|::ResipLogger:Send: SipReq:  REGISTER sip.skype.com:5060 tid=6b6afe1c1641e82d cseq=REGISTER [email protected]:5060 / 30 from(tu)
16:09:18.488|.\SipStack.cxx(314)|Debug8|Resip|::ResipLogger:SEND: SipReq:  REGISTER sip.skype.com:5060 tid=6b6afe1c1641e82d cseq=REGISTER [email protected]:5060 / 30 from(tu)
16:09:18.585|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer F tid=6b6afe1c1641e82d ms=32000
16:09:18.585|.\DnsResult.cxx(214)|Debug8|Resip|::ResipLogger:DnsResult::lookup sip:[email protected];transport=UDP
16:09:18.585|.\dns\DnsStub.cxx(65)|Debug8|Resip|::ResipLogger:_sip._udp.sip.skype.com (SRV) --> p=0 w=0 1.sip.skype.com:5060_sip._udp.sip.skype.com (SRV) --> p=1 w=0 2.sip.skype.com:5060
16:09:18.585|.\dns\DnsStub.cxx(47)|Debug8|Resip|::ResipLogger:1.sip.skype.com(A)--> 63.209.144.201
16:09:18.585|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer E1 tid=6b6afe1c1641e82d ms=500
16:09:18.591|.\TransportSelector.cxx(562)|Debug8|Resip|::ResipLogger:Looked up source for destination: [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ] -> [ V4 192.168.15.25:0 UDP target domain=sip.skype.com mFlowKey=0 ] sent-by= sent-port=0
16:09:18.591|.\TransportSelector.cxx(1107)|Debug8|Resip|::ResipLogger:findTransportBySource([ V4 192.168.15.25:0 UDP target domain=sip.skype.com mFlowKey=0 ])
16:09:18.591|.\TransportSelector.cxx(1208)|Debug8|Resip|::ResipLogger:findTransport (any port, specific interface) => Transport: [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ] on 192.168.15.25
16:09:18.591|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=sip.skype.com mFlowKey=0 ]
Via: SIP/2.0/UDP 192.168.15.25:5060;branch=z9hG4bK-d8754z-6b6afe1c1641e82d-1---d8754z-;rport
Max-Forwards: 70
CSeq: 30 REGISTER
Expires: 60
Supported: replaces
Content-Length: 0
16:09:18.591|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 63.209.144.201:5060 UDP target domain=sip.skype.com mFlowKey=0 ]
16:09:18.817|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 63.209.144.201:5060 UDP target domain=unspecified mFlowKey=852 ]
16:09:18.817|.\DnsResult.cxx(206)|Debug8|Resip|::ResipLogger:Whitelisting _sip._udp.sip.skype.com(33): 1.sip.skype.com:5060
16:09:18.817|.\dns\RRVip.cxx(129)|Debug8|Resip|::ResipLogger:updating an existing vip: 1.sip.skype.com:5060 with 1.sip.skype.com:5060
16:09:18.817|.\DnsResult.cxx(206)|Debug8|Resip|::ResipLogger:Whitelisting sip.skype.com(1): 63.209.144.201
16:09:18.817|.\dns\RRVip.cxx(129)|Debug8|Resip|::ResipLogger:updating an existing vip: 63.209.144.201 with 63.209.144.201
16:09:18.817|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=4
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.15.25:5060;branch=z9hG4bK-d8754z-6b6afe1c1641e82d-1---d8754z-;rport=5060;received=200.33.148.100
Contact: <sip:[email protected]:5060;rinstance=6a250f847867869e;transport=udp>;expires=45
To: <sip:[email protected]:5060>;tag=c97b4d1cb1f3d0da549e06a8d482ef63.ade7
CSeq: 30 REGISTER
Expires: 45
Server: OpenSIPS
Content-Length: 0
16:09:18.817|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer K tid=6b6afe1c1641e82d ms=5000
16:09:18.818|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:18.818|.\DialogUsageManager.cxx(1333)|Trace5|Resip|::ResipLogger:Got: SipResp: 200 tid=6b6afe1c1641e82d cseq=REGISTER [email protected]:5060 / 30 from(wire)
16:09:18.818|.\DialogUsageManager.cxx(1841)|Debug8|Resip|::ResipLogger:DialogUsageManager::processResponse:
16:09:18.818|.\UserProfile.cxx(158)|Debug8|Resip|::ResipLogger:Found credential for realm: realm=3CXPhoneSystem user=65510001150693CXPhoneSystem
16:09:18.818|.\ClientAuthManager.cxx(41)|Debug8|Resip|::ResipLogger:ClientAuthManager::handle: transitioning Nzk1NWU2MDEzMTgyODVlMmM3YmRhMDcwODUxOWUwMGE.-0d33323eto cached
16:09:18.818|.\ClientAuthManager.cxx(198)|Debug8|Resip|::ResipLogger:ClientAuthManager::RealmState::transition from current to cached
16:09:18.819|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: Nzk1NWU2MDEzMTgyODVlMmM3YmRhMDcwODUxOWUwMGE.-0d33323e-c97b4d1cb1f3d0da549e06a8d482ef63.ade7
16:09:18.819|.\ClientRegistration.cxx(402)|Debug8|Resip|::ResipLogger:Clearing service route ([])
16:09:18.819|.\TimerQueue.cxx(105)|Debug8|Resip|::ResipLogger:Adding application timer: DumTimeout::Registration ClientRegistration sip:[email protected]:5060: duration=40 seq=15
16:09:18.919|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:19.019|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:19.419|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:24.497|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ]
16:09:24.497|.\TransactionUser.cxx(66)|Debug8|Resip|::ResipLogger:Checking if SipReq:  REGISTER 192.168.15.25:5060 tid=6f2acd0b045da973 cseq=REGISTER [email protected]:52113 / 25 from(wire) is for me
16:09:24.498|.\TransactionUser.cxx(71)|Debug8|Resip|::ResipLogger:Checking rule...
16:09:24.498|.\MessageFilterRule.cxx(42)|Debug8|Resip|::ResipLogger:Matching rule for:
REGISTER sip:192.168.15.25:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.15.3:52113;branch=z9hG4bK-d8754z-6f2acd0b045da973-1---d8754z-;rport=52113
Max-Forwards: 70
Contact: <sip:[email protected]:52113;rinstance=b8949f572af0e859>
To: "Hector Fdz"<sip:[email protected]:5060>
From: "Hector Fdz"<sip:[email protected]:5060>;tag=3268b15c
Call-ID: NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.
CSeq: 25 REGISTER
Expires: 120
Proxy-Authorization: Digest username="Ext.1000",realm="3CXPhoneSystem",nonce="414d535c05a6559858:64764571f8f24b25fb8811f93a769545",uri="sip:192.168.15.25:5060",response="7c0e4e0a0636b9cd5c8f1d5597ddc45d",algorithm=MD5
Supported: replaces
User-Agent: 3CXPhone 6.0.18815.0
Content-Length: 0
16:09:24.498|.\TransactionUser.cxx(74)|Debug8|Resip|::ResipLogger:Match!
16:09:24.498|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=6f2acd0b045da973 cseq=REGISTER [email protected]:52113 / 25 from(wire) code=100 reason=
16:09:24.498|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer Trying tid=6f2acd0b045da973 ms=3500
16:09:24.498|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
Max-Forwards: 70
CSeq: 25 REGISTER
Expires: 120
Supported: replaces
Content-Length: 0
16:09:24.499|.\Authorization.cpp(874)|Debug2||FindBlacklistEntry:EBL: IPBL found ip = 192.168.15.3; result = not found
16:09:24.499|.\ServerAuthManager.cxx(337)|Trace5|Resip|::ResipLogger:Requesting credential for Ext.1000 @ 3CXPhoneSystem
16:09:24.499|.\DialogSetId.cxx(34)|Debug8|Resip|::ResipLogger:********** Generated Local Tag ***********
16:09:24.499|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.-5d07cb0b-3268b15c
16:09:24.499|.\ServerAuthManager.cxx(51)|Trace5|Resip|::ResipLogger:ServerAuth requested credentials SipReq:  REGISTER 192.168.15.25:5060 tid=6f2acd0b045da973 cseq=REGISTER [email protected]:52113 / 25 from(wire)
16:09:24.500|.\Helpers.cpp(32)|Debug2||Helpers::Authenticate:[Auth] Expired nonce: (414d535c05a6559858:64764571f8f24b25fb8811f93a769545) made 108 sec. ago
16:09:24.500|.\ServerAuthManager.cxx(129)|Trace5|Resip|::ResipLogger:Checking for auth result in realm=3CXPhoneSystem A1=
16:09:24.500|.\ServerAuthManager.cxx(202)|Trace5|Resip|::ResipLogger:Nonce expired for Ext.1000
16:09:24.500|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=6f2acd0b045da973 cseq=REGISTER [email protected]:52113 / 25 from(wire) code=407 reason=
16:09:24.500|.\ServerAuthManager.cxx(394)|Trace5|Resip|::ResipLogger:Sending challenge to SipReq:  REGISTER 192.168.15.25:5060 tid=6f2acd0b045da973 cseq=REGISTER [email protected]:52113 / 25 from(wire)
16:09:24.500|.\DialogUsageManager.cxx(866)|Debug8|Resip|::ResipLogger:SEND:
[b]
SIP/2.0 407 Proxy Authentication Required[/b]
Proxy-Authenticate: Digest nonce="414d535c05a6560415:511be7e24f45a0a9ed3a726d1dc58965",algorithm=MD5,realm="3CXPhoneSystem"
To: "Hector Fdz"<sip:[email protected]:5060>;tag=3334b156
CSeq: 25 REGISTER
Content-Length: 0
16:09:24.501|.\SipStack.cxx(296)|Debug8|Resip|::ResipLogger:SEND: SipResp: 407 tid=6f2acd0b045da973 cseq=REGISTER / 25 from(tu)
16:09:24.501|.\ServerAuthManager.cxx(110)|Trace5|Resip|::ResipLogger:ServerAuth rejected request UserAuthInfo Ext.1000 @ 3CXPhoneSystem A1=
16:09:24.598|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer J tid=6f2acd0b045da973 ms=32000
16:09:24.598|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ]
[b]SIP/2.0 407 Proxy Authentication Required[/b]
CSeq: 25 REGISTER
Content-Length: 0
16:09:24.598|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ]
16:09:24.718|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ]
16:09:24.718|.\TransactionUser.cxx(66)|Debug8|Resip|::ResipLogger:Checking if SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire) is for me
16:09:24.718|.\TransactionUser.cxx(71)|Debug8|Resip|::ResipLogger:Checking rule...
16:09:24.718|.\MessageFilterRule.cxx(42)|Debug8|Resip|::ResipLogger:Matching rule for:
Via: SIP/2.0/UDP 192.168.15.3:52113;branch=z9hG4bK-d8754z-2d0b89745907e067-1---d8754z-;rport=52113
Max-Forwards: 70
CSeq: 26 REGISTER
Expires: 120
Proxy-Authorization: Digest username="Ext.1000",realm="3CXPhoneSystem",nonce="414d535c05a6560415:511be7e24f45a0a9ed3a726d1dc58965",uri="sip:192.168.15.25:5060",response="5afb6107d30f3fffddc42b6639844cdc",algorithm=MD5
Supported: replaces
Content-Length: 0
16:09:24.718|.\TransactionUser.cxx(74)|Debug8|Resip|::ResipLogger:Match!
16:09:24.719|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire) code=100 reason=
16:09:24.719|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer Trying tid=2d0b89745907e067 ms=3500
16:09:24.719|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
Max-Forwards: 70
CSeq: 26 REGISTER
Expires: 120
Supported: replaces
Content-Length: 0
16:09:24.719|.\Authorization.cpp(874)|Debug2||FindBlacklistEntry:EBL: IPBL found ip = 192.168.15.3; result = not found
16:09:24.719|.\ServerAuthManager.cxx(337)|Trace5|Resip|::ResipLogger:Requesting credential for Ext.1000 @ 3CXPhoneSystem
16:09:24.719|.\DialogSetId.cxx(34)|Debug8|Resip|::ResipLogger:********** Generated Local Tag ***********
16:09:24.719|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.-b20dba4c-3268b15c
16:09:24.720|.\ServerAuthManager.cxx(51)|Trace5|Resip|::ResipLogger:ServerAuth requested credentials SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire)
16:09:24.720|.\Helpers.cpp(71)|Debug2||Helpers::Authenticate:[Auth] Saving nonce (414d535c05a6560415:511be7e24f45a0a9ed3a726d1dc58965) for user [Ext.1000] at pos=1
16:09:24.720|.\ServerAuthManager.cxx(129)|Trace5|Resip|::ResipLogger:Checking for auth result in realm=3CXPhoneSystem A1=
16:09:24.720|.\ServerAuthManager.cxx(214)|Trace5|Resip|::ResipLogger:Authorized request for 3CXPhoneSystem
16:09:24.721|.\Authorization.cpp(151)|Trace5|Authorization|AuthMgr::onAuthSuccess:Caller "Hector Fdz"<sip:[email protected]:5060>;tag=3268b15c has been authenticated successfully
16:09:24.721|.\Authorization.cpp(161)|Trace5|Authorization|AuthMgr::onAuthSuccess:Successful authentication from IP: 192.168.15.3
16:09:24.721|.\DialogUsageManager.cxx(1333)|Trace5|Resip|::ResipLogger:Got: SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire)
16:09:24.721|.\DialogUsageManager.cxx(1651)|Debug8|Resip|::ResipLogger:DialogUsageManager::processRequest: SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire)
16:09:24.721|.\DialogSetId.cxx(34)|Debug8|Resip|::ResipLogger:********** Generated Local Tag ***********
16:09:24.722|.\DialogSetId.cxx(34)|Debug8|Resip|::ResipLogger:********** Generated Local Tag ***********
16:09:24.722|.\DialogSet.cxx(85)|Debug8|Resip|::ResipLogger: ************* Created DialogSet(UAS)  -- NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.-09043d66*************
16:09:24.722|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.-4d6c4a32-3268b15c
16:09:24.722|.\ServerRegistration.cxx(110)|Debug8|Resip|::ResipLogger:got a registration
16:09:24.722|.\RegistrarDB.cpp(285)|Trace5||RegistrarDB::getContacts:Found 1 contact(s) for AOR sip:[email protected]:5060
16:09:24.722|.\ServerRegistration.cxx(248)|Debug8|Resip|::ResipLogger:instance or reg-id missing
16:09:24.723|.\ServerRegistration.cxx(328)|Trace5|Resip|::ResipLogger:Adding sip:[email protected]:5060 -> <sip:[email protected]:52113;rinstance=b8949f572af0e859>
16:09:24.723|.\ServerRegistration.cxx(329)|Debug8|Resip|::ResipLogger:Contact has tuple [ V4 0.0.0.0:0 UNKNOWN_TRANSPORT target domain=unspecified mFlowKey=0 ]
16:09:24.723|.\RegistrarDB.cpp(163)|Trace5||RegistrarDB::updateContact:Update AOR sip:[email protected]:5060 with contact [<sip:[email protected]:52113;rinstance=b8949f572af0e859>]
16:09:24.723|.\RegistrarDB.cpp(181)|Debug2||RegistrarDB::updateContact:Updated; cid = 3151313435
16:09:24.723|.\RegistrarDB.cpp(319)|Trace5||RegistrarDB::getDNsContactIds:There's 1 contact record(s) found for DN 1000
16:09:24.724|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire) code=200 reason=
16:09:24.724|.\ServerRegistration.cxx(45)|Trace5|Resip|::ResipLogger:accepted a registration sip:[email protected]:5060
16:09:24.724|.\RegistrarDB.cpp(285)|Trace5||RegistrarDB::getContacts:Found 1 contact(s) for AOR sip:[email protected]:5060
16:09:24.724|.\DialogUsageManager.cxx(866)|Debug8|Resip|::ResipLogger:SEND:
SIP/2.0 200 OK
Contact: <sip:[email protected]:52113;rinstance=b8949f572af0e859>;expires=120
To: "Hector Fdz"<sip:[email protected]:5060>;tag=8028e01c
CSeq: 26 REGISTER
Content-Length: 0
16:09:24.724|.\SipStack.cxx(296)|Debug8|Resip|::ResipLogger:SEND: SipResp: 200 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(tu)
16:09:24.725|.\RegistrarDB.cpp(351)|Debug2||RegistrarDB::findContId:Look for contact: sip:[email protected]:52113;rinstance=b8949f572af0e859
16:09:24.725|.\DevsMgr.cpp(260)|Trace5||Device::updateTransport:Updating device by message: SipReq:  REGISTER 192.168.15.25:5060 tid=2d0b89745907e067 cseq=REGISTER [email protected]:52113 / 26 from(wire)
16:09:24.729|.\CallMgr.cpp(1066)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:Check locality of IP 192.168.15.3
16:09:24.729|.\CallMgr.cpp(1072)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IPADDR(0): addr = 127.0.0.1, mask 255.0.0.0
16:09:24.729|.\CallMgr.cpp(1072)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IPADDR(1): addr = 192.168.15.25, mask 255.255.255.0
16:09:24.729|.\CallMgr.cpp(1075)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IP 192.168.15.3 is local
16:09:24.732|.\DevsMgr.cpp(208)|Trace5||Device::update:PBX contact is local IP: sip:[email protected]:5060
16:09:24.738|.\DBAccessor.cpp(1633)|Trace5|DataBase|DBConfigAccessor::addRegistrarContact:Update registration: key=1000;contact=sip:[email protected]:52113;rinstance=b8949f572af0e859; id=28
16:09:24.738|.\DialogUsageManager.cxx(2143)|Debug8|Resip|::ResipLogger:Got merged request removal request
16:09:24.738|.\TimerQueue.cxx(105)|Debug8|Resip|::ResipLogger:Adding application timer:
16:09:24.738|.\DialogSet.cxx(123)|Debug8|Resip|::ResipLogger: ********** DialogSet::~DialogSet: NDA3N2MwZGQzOGM5YTEzNjlhN2ZiZTQyYmFlZGIyZDQ.-09043d66*************
16:09:24.738|.\RegistrarDB.cpp(351)|Debug2||RegistrarDB::findContId:Look for contact: sip:[email protected]:52113;rinstance=b8949f572af0e859
16:09:24.738|.\ExtnMgr.cpp(758)|Debug2||ExtnMgr::onRegUpdContact:Issue: [pres:1000;2;reg;107]
16:09:24.819|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer J tid=2d0b89745907e067 ms=32000
16:09:24.819|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ]
SIP/2.0 200 OK
CSeq: 26 REGISTER
Content-Length: 0
16:09:24.819|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 192.168.15.3:52113 UDP target domain=unspecified mFlowKey=852 ]
16:09:28.769|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:28.869|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:29.019|.\DialogUsageManager.cxx(2151)|Debug8|Resip|::ResipLogger:Merged request removed
16:09:37.423|.\TuSelector.cxx(70)|Trace5|Resip|::ResipLogger:Stats message
16:09:37.423|.\StatisticsMessage.cxx(152)|Trace5|Resip|::ResipLogger:RESIP:TRANSACTION
TU summary: 0 TRANSPORT 0 TRANSACTION 0 CLIENTTX 0 SERVERTX 2 TIMERS 4
Transaction summary: reqi 174 reqo 60 rspi 60 rspo 173
Details: INVi 0/S0/F0 INVo 0/S0/F0 ACKi 0 ACKo 0 BYEi 0/S0/F0 BYEo 0/S0/F0 CANi 0/S0/F0 CANo 0/S0/F0 MSGi 0/S0/F0 MSGo 0/S0/F0 OPTi 0/S0/F0 OPTo 0/S0/F0 REGi 173/S86/F86 REGo 34/S17/F17 PUBi 0/S0/F0 PUBo 0/S0/F0 SUBi 1/S0/F1 SUBo 0/S0/F0 NOTi 0/S0/F0 NOTo 26/S0/F26
Retransmissions: INVx 0 BYEx 0 CANx 0 MSGx 0 OPTx 0 REGx 0 finx 0 nonx 0 PUBx 0 SUBx 0 NOTx 0
16:09:37.945|.\RegistrarDB.cpp(305)|Trace5||RegistrarDB::getAllContactIds:There's 27 contact(s) registered
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=d0ea400c6faef20a; expires in 249
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=1e5c7674e310f02b; expires in 249
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=bcb2c750b435d835; expires in 249
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=7b7e1471a7d36d56; expires in 250
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=10d60c21a58c1d02; expires in 249
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=783887833ab6ed92; expires in 250
16:09:37.945|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=a896d0031e0794c4; expires in 249
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=32f582c9dc914162; expires in 259
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=5e2ae4b27d522892; expires in 250
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:5488; expires in 66
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:5100;user=phone; expires in 303
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=27bfa90cc80741d9; expires in 259
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=9548e2fe83b17d3c; expires in 259
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=1d2da71bf43c0737; expires in 259
16:09:37.946|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=c9b8c5d0e57ceb2c; expires in 249
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=69a7c3604675f8a9; expires in 249
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=71bed7fd37f5c94c; expires in 249
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=4de93dc5aa505c66; expires in 249
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=0347b5ffa113ba9f; expires in 249
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=4cdd34279a0678ed; expires in 250
16:09:37.947|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=69e971c725bc31c2; expires in 249
16:09:37.948|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40300;rinstance=cc31634186d93af5; expires in 250
16:09:37.948|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=a859b927a8376531; expires in 259
16:09:37.948|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:52113;rinstance=b8949f572af0e859; expires in 107
16:09:37.948|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40000;rinstance=72ace2a26aa89512; expires in 249
16:09:37.948|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:*[email protected]:40000;rinstance=73caef594d481bf8; expires in 249
16:09:37.949|.\Registrar.cpp(97)|Debug2|Registrar|ServRegs::checkExpiration:Checking sip:[email protected]:40600;rinstance=6bd1becbde949030; expires in 259
16:09:39.380|.\Call.cpp(48)|Log5||??:Currently active calls [none]
16:09:40.166|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ]
16:09:40.166|.\TransactionUser.cxx(66)|Debug8|Resip|::ResipLogger:Checking if SipReq:  REGISTER 192.168.15.25:5060 tid=4944F7C7 cseq=REGISTER [email protected]:5100 / 5 from(wire) is for me
16:09:40.166|.\TransactionUser.cxx(71)|Debug8|Resip|::ResipLogger:Checking rule...
16:09:40.167|.\MessageFilterRule.cxx(42)|Debug8|Resip|::ResipLogger:Matching rule for:
Via: SIP/2.0/UDP 192.168.15.25:5100;branch=z9hG4bK4944F7C7
Max-Forwards: 70
Route: <sip:192.168.15.25:5060;lr>
Contact: <sip:[email protected]:5100;user=phone>
To: <sip:[email protected]:5060;user=phone>
Call-ID: [email protected]
CSeq: 5 REGISTER
Expires: 600
Allow: INVITE, BYE, ACK, OPTIONS, CANCEL
Proxy-Authorization: Digest username="8888",realm="3CXPhoneSystem",nonce="414d535c05a654e767:00462cc21e3e920d6ad98012a3ac991c",uri="sip:192.168.15.25",response="ba6f84c985b615c5cddc2b5809e5dbbf",algorithm=MD5,cnonce="7012",opaque="",nc=00000002
User-Agent: Netbricks-Sip-T.38IAF/2.01 (PRODUCT ID:5, 05 Jul 2007)
Content-Length: 0
16:09:40.167|.\TransactionUser.cxx(74)|Debug8|Resip|::ResipLogger:Match!
16:09:40.167|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=4944F7C7 cseq=REGISTER [email protected]:5100 / 5 from(wire) code=100 reason=
16:09:40.167|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer Trying tid=4944F7C7 ms=3500
16:09:40.167|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
Max-Forwards: 70
CSeq: 5 REGISTER
Expires: 600
Content-Length: 0
16:09:40.167|.\Authorization.cpp(874)|Debug2||FindBlacklistEntry:EBL: IPBL found ip = 192.168.15.25; result = not found
16:09:40.167|.\ServerAuthManager.cxx(337)|Trace5|Resip|::ResipLogger:Requesting credential for 8888 @ 3CXPhoneSystem
Proxy-Authenticate: Digest nonce="414d535c05a6561494:97da083cfd60b317c8bc440c2718135e",algorithm=MD5,realm="3CXPhoneSystem"
To: <sip:[email protected]:5060;user=phone>;tag=f57b0c55
CSeq: 5 REGISTER
Content-Length: 0
16:09:40.169|.\SipStack.cxx(296)|Debug8|Resip|::ResipLogger:SEND: SipResp: 407 tid=4944F7C7 cseq=REGISTER / 5 from(tu)
16:09:40.169|.\ServerAuthManager.cxx(110)|Trace5|Resip|::ResipLogger:ServerAuth rejected request UserAuthInfo 8888 @ 3CXPhoneSystem A1=
16:09:40.267|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer J tid=4944F7C7 ms=32000
16:09:40.267|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ]
CSeq: 5 REGISTER
Content-Length: 0
16:09:40.267|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ]
16:09:40.268|.\Transport.cxx(287)|Debug8|Resip|::ResipLogger:incoming from: [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ]
16:09:40.268|.\TransactionUser.cxx(66)|Debug8|Resip|::ResipLogger:Checking if SipReq:  REGISTER 192.168.15.25:5060 tid=F0472E44 cseq=REGISTER [email protected]:5100 / 6 from(wire) is for me
16:09:40.268|.\TransactionUser.cxx(71)|Debug8|Resip|::ResipLogger:Checking rule...
16:09:40.268|.\MessageFilterRule.cxx(42)|Debug8|Resip|::ResipLogger:Matching rule for:
Via: SIP/2.0/UDP 192.168.15.25:5100;branch=z9hG4bKF0472E44
Max-Forwards: 70
CSeq: 6 REGISTER
Expires: 600
Proxy-Authorization: Digest username="8888",realm="3CXPhoneSystem",nonce="414d535c05a6561494:97da083cfd60b317c8bc440c2718135e",uri="sip:192.168.15.25",response="23c0fa2c635b8c13989414f041ee1300",algorithm=MD5,cnonce="7012",opaque="",nc=00000001
Content-Length: 0
16:09:40.268|.\TransactionUser.cxx(74)|Debug8|Resip|::ResipLogger:Match!
16:09:40.268|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  REGISTER 192.168.15.25:5060 tid=F0472E44 cseq=REGISTER [email protected]:5100 / 6 from(wire) code=100 reason=
16:09:40.268|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer Trying tid=F0472E44 ms=3500
16:09:40.269|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
Max-Forwards: 70
CSeq: 6 REGISTER
Expires: 600
Content-Length: 0
16:09:40.269|.\Authorization.cpp(874)|Debug2||FindBlacklistEntry:EBL: IPBL found ip = 192.168.15.25; result = not found
16:09:40.269|.\ServerAuthManager.cxx(337)|Trace5|Resip|::ResipLogger:Requesting credential for 8888 @ 3CXPhoneSystem
SIP/2.0 200 OK
Contact: <sip:[email protected]:5100;user=phone>;expires=600
To: <sip:[email protected]:5060;user=phone>;tag=093bef6e
CSeq: 6 REGISTER
Content-Length: 0
16:09:40.281|.\SipStack.cxx(296)|Debug8|Resip|::ResipLogger:SEND: SipResp: 200 tid=F0472E44 cseq=REGISTER [email protected]:5100 / 6 from(tu)
16:09:40.281|.\RegistrarDB.cpp(351)|Debug2||RegistrarDB::findContId:Look for contact: sip:[email protected]:5100;user=phone
16:09:40.281|.\DevsMgr.cpp(260)|Trace5||Device::updateTransport:Updating device by message: SipReq:  REGISTER 192.168.15.25:5060 tid=F0472E44 cseq=REGISTER [email protected]:5100 / 6 from(wire)
16:09:40.284|.\CallMgr.cpp(1066)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:Check locality of IP 192.168.15.25
16:09:40.284|.\CallMgr.cpp(1072)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IPADDR(0): addr = 127.0.0.1, mask 255.0.0.0
16:09:40.284|.\CallMgr.cpp(1072)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IPADDR(1): addr = 192.168.15.25, mask 255.255.255.0
16:09:40.284|.\CallMgr.cpp(1075)|Debug2|CallManager|CallMgr::isIpInLocalNetwork:IP 192.168.15.25 is local
16:09:40.287|.\DevsMgr.cpp(208)|Trace5||Device::update:PBX contact is local IP: sip:[email protected]:5060
16:09:40.292|.\DBAccessor.cpp(1633)|Trace5|DataBase|DBConfigAccessor::addRegistrarContact:Update registration: key=8888;contact=sip:[email protected]:5100;user=phone; id=1
16:09:40.292|.\DialogUsageManager.cxx(2143)|Debug8|Resip|::ResipLogger:Got merged request removal request
16:09:40.292|.\TimerQueue.cxx(105)|Debug8|Resip|::ResipLogger:Adding application timer:
16:09:40.292|.\DialogSet.cxx(123)|Debug8|Resip|::ResipLogger: ********** DialogSet::~DialogSet: [email protected]*************
16:09:40.369|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer J tid=F0472E44 ms=32000
16:09:40.369|.\TransportSelector.cxx(940)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ] tlsDomain= via [ V4 192.168.15.25:5060 UDP target domain=unspecified mFlowKey=852 ]
SIP/2.0 200 OK
CSeq: 6 REGISTER
Content-Length: 0
16:09:40.369|.\Transport.cxx(213)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 192.168.15.25:5100 UDP target domain=unspecified mFlowKey=852 ]
If the registration of the Skype trunk looks normal, (it shows as registered), then try directing the (all) incoming call(s) just to an extension or ring group rather than handling as a DID, something simple, just to be sure that it works. then move on.
Hi Leejor,
i was solve the problem!
the issue was the stun server is not compatible or something and the ddns aparently not work with 3cx, so i put the public ip where it mention for register, and turn off the stun server and in the ip provider, i choose register in and out using public ip.
:D thanks Leejor
now i have some question but i will create another topic.... the question is if 3cx can be able to record the incoming calls not answered but in the pbx, not in the history of the terminal phone... :S
Get 3CX - Absolutely Free!
3CX
