VoIP Status dropping registration
Discussion in '3CX Phone System - General' started by IrvineCAGuy, Dec 3, 2013.
  1. IrvineCAGuy
    Feb 9, 2009
    6
    I'm trying to diagnose or pinpoint the potential source of this problem:
    On a Ver 10 system running on an Intel Atom platform and XP, I get periodically "dropped" from the VoIP registration.
    No incoming nor outgoing calls.
    This system has been running for a long time with 100% up-time, until recently.
    I've installed Ver 12 on an WIndows 7 Pro platform, however here I lose registration even more frequently.
    Rebooting either server usually reconnects the registration with my VoIP provider, but not for long.
    I am "testing" with using DSL with 60kb up and 4mb down.
    So, where can the problem be? My DSL connection? My VoIP provider? Or both computers are not behaving?
  2. DJHiP
    Dec 2, 2009
    29
    What time do you have set in VoIP Provider -> Advanced for 'Time between registration attempts (in seconds)' ?
    And this is on the same Modem/Router, no firmware updates performed which may have affected the NAT timeout?
    Lastly what does the Server Activity Log say when the VoIP Provider drops?
